Can someone look at their fuel injector wires please?
I took my wires off to redo the harness and now I can't remember which way it's supposed to go. The part at the top where the plugs are I didn't touch so there in the right order, but I need to know what color wire is on the pass side cylinder, I assume that's the #1 cyl? Thanks in advance!
The passenger side cylinder is #4. #1 is closest to the timing belt. If I still had my h23 I could take a picture of it, but I swapped to the h22, and I can't seem to find a picture on google close enough to help any.
Ah, well thanks anyway. At least I know the cylinder numbers now, lol. So yeah, if anyone can tell me the colors of ANY of the wires and what cylinder it goes to I can figure out the rest, I just need that first one to get me started
What color are your wires? I'll go see if they're the same color as the h22. Honda likes to make things difficult, but it might be the same lol.
I have had this for awhile, and was looking at it for the knock sensor: http://www.dodo-upgrades.nl/pinoutp06p28p30.htm I wonder if the wire colors are the same for this? If I put it on backwards will it tear anything up, or will it just run wrong? I could always install it, and then swap it around if it's wrong. I just don't want to **** anything up is all.
Straight from the page I posted above: INJ - Injector, the number refers to the cylinder used (1 is on the side with the belts)
Now all I have to do is find an H23 ecu pinout and I'm golden!
I honestly don't know if it would mess anything up setting the plugs backwards. Are you trying to reconnect the wires into the plugs? The 2 lil wires that go on top? Just making sure, so I'm not looking at different wires lol. Cuz on mine, on the passenger side cylinder on the injector, the red wire is on the passenger side, and the yellow is on the driver side, for that injector.
Edit: Oh you're trying to connect the wires on the ECU?
I thought you were trying to reconnect the wires straight into the Injector Plugs lol.
I'll see if I can't find an h23 ecu pinout. I have one bookmarked for an h22a straight off honda tech but I can't find one for h23 just yet.
http://www.ff-squad.com/technet/wiring.obd1.htm
According to this, they're all the same. So my vtec ECU, would be the same as your non-vtec ecu. That is for a manual ECU.
Well I am trying to do the injectors themselves, just the 2 wires, but I was going off of that because it had the colors on it. One other question... your v-tec solenoid, how many wires go to it, and what color is the plug/wire that goes to it? I think the harness I got with my swap is an H22 harness, I have an extra plug and it has no home... think it might be for that...
I'll post up as soon as I get out there.
