Max Rpm on a fresh d16?
Old Sep 14, 2010 | 12:50 AM
MitsuChevyHonda's Avatar
Default Max Rpm on a fresh d16?
Well I got a 93 ex with a blown motor and tranny for $75. I just got a new d16 and tranny, started with tearing down the new motor and replacing the rings bearings water and oil pump. No before we get started I am not a noob by any means to cars, nitrous, turbos, superchargers, v8's, I4's. I have a 8sec nova on a 400shot nitrous and a 10sec eclipse fully built with a 67mm. So anyways the plan for the civic is to say n/a and be a dd. I tune my own cars and have been reading up on chrome and will be tuning the civic myself also. I ported the head slightly and plan on getting a cam and valvesprings along with a skunk2 IM and a TB, also 450 dsm injectors walbro, ebay headers, test pipe, catback, with a vibrant muffler welded on. Yes I know cheaping out on exhaust but it came with it, just gonna weld on a vibrant muffler and call it a day. So if your still reading heres my question, Whats the max everyone is reving a d16 to?
Old Sep 14, 2010 | 04:55 AM
JasonYo's Avatar
Default Re: Max Rpm on a fresh d16?
I usually don't go past 7k
Old Sep 14, 2010 | 05:14 AM
Crashtestdummy's Avatar
My rev limiter from my tuned ecu hits 6.8 so yeah 7k sounds about right
Old Sep 14, 2010 | 07:45 AM
92lxsleeper's Avatar
if you upgrade the springs and retainers and have a cam that benefits from higher rpms, then you could run the bottom end to around 8 to 8500, any higher and i would suggest taking the crank, flywheel, and crank pulley to a machinist to have them balanced for 10k rpms.
i really dont understand the need for high rpms tho. the higher it revs just means the longer you have to wait to get into the powerband and shift to a next gear.
Old Sep 14, 2010 | 09:21 AM
Libertariat's Avatar
Ek Forever y0!
This.
High rpms =/= more power.
There's a lot more involved.
Unless you're getting some massive increase in air, increasing your fuel is just going to make you run rich.
I'm not sure what the hell you're trying to do. N/A D-series builds are respectable but you're beating around the bush quite a bit.
Old Sep 14, 2010 | 09:52 AM
owneyboy's Avatar
stock d16z6 will handle revs up to 8k all day every day but for safety 7500 or stock is perfect. no need to rev out you will stop making power around 6200-6600 with stock cam. powerband will drop and you will just be making more noise and moving slower.
Old Sep 14, 2010 | 10:49 AM
devney's Avatar
Definitely wouldn't recommend this unless you want to blow your engine.
Old Sep 14, 2010 | 12:25 PM
As I posted Im gettting a cam and springs more worried/talking about the bottom end. Forgot to mention the rotating assembly was balanced, didnt put that as Ive never taking a motor apart and not had that done before putting it back together. The point of the question is to see what cam I will be getting, my friend can design custom cams as he use to work for a major aftermarket company. When I tune the car obviously Ill stop reving where it stops making power.
Old Sep 14, 2010 | 03:34 PM
Oh and its a y6 block, with a z6 head.
Old Sep 14, 2010 | 04:18 PM
EJeff8's Avatar
No need to waste money on any of this on a N/A build.
Old Sep 14, 2010 | 04:21 PM
I have the injectors left over from my eclipse, and the manifold an tb a friend has for 100 so why not lol.
Old Sep 14, 2010 | 04:23 PM
EJeff8's Avatar
^Adding that exhaust along with it, you'd be doing far more harm than good.
Pressure will be non existent in your engine.
Old Sep 14, 2010 | 04:26 PM
Also I might setup a nitrous kit later on. Plus the intake mani takes away from the rasp
Old Sep 14, 2010 | 04:27 PM
Its a 2.5" exhaust. Not my first time building a car lol
Also I will be adding a high flow cat instead of the test pipe to help with the rasp
Old Sep 14, 2010 | 04:28 PM
EJeff8's Avatar
The NX kit would help this setup you want to do.
And i don't think it would, at all. That's all intake/ exhaust
Old Sep 14, 2010 | 04:29 PM
EJeff8's Avatar
Its a 2.5" exhaust.
If you weren't boosting or Nosing it, that'd be too much. 2 1/4 is much better on an N/A.
Old Sep 14, 2010 | 04:32 PM
Its fine as Im putting a camber muffler and high flow cat. Its also not jdm style lol and has bends in it, mandrel ofcorse. I know how back pressure works.
Old Sep 14, 2010 | 04:35 PM
EJeff8's Avatar
Meh, I could be just pushing buttons but a lot of that seems like overkill is all. Whether it be free or not.
Old Sep 14, 2010 | 04:46 PM
The intake is also 2.5" to help mid range power. Id rather get the parts now for cheap then later when/if I get a nitrous system. I also have the other block which is good and may do a build later on. But really my main goal is decent power and a honda that sounds good. Which is rare to find a good sounding <2.0l, without a turbo or fully built.
This is my winter car/beater car for when my other cars are getting mods done or its shitty out.
Old Sep 14, 2010 | 04:50 PM
Back on topic whats the max I can safely rev a balance d16 to with the supporting mods to make power up top and the valetrain to sustain high rpm?
Old Sep 14, 2010 | 05:33 PM
Ek Forever y0!
The better question is:
"At what RPM do I lose power in the power band?"
Because that's a lot lower than the reving potential of a d-series.
Old Sep 14, 2010 | 05:37 PM
Im going top have a custom cam that will be designed for just under the max rpm. Unless your saying a d16 can rev out like a r6 and redline at 16.5k?
Old Sep 14, 2010 | 05:38 PM
EJeff8's Avatar
^He's saying D's aren't meant for revving at all. B's make their power from revving.
Old Sep 14, 2010 | 06:01 PM
300whpej's Avatar
i would stay under 8k for sure. the rods and crank will be working there *** of at that speed.
Old Sep 14, 2010 | 06:03 PM
So then what is the max? I was just read a d16 turbo build where they are reving to 9.1k. So what high 8's?
