B16 misfire
Old Sep 13, 2010 | 05:30 PM
JDMFEVER's Avatar
Default B16 misfire
When I drive my car at any type of throttle at 2500rpm or lower, the car sputters as if it were misfiring. And it only does it on idle when the a/c is on. My a/c also at times does not cool properly. All cylinders are firing. Plugs wires and dizzy have been replaced. Problem started two months after the car had been sitting for 5 months. Could this be fuel or timing? And if so, what should the timing be set at?
Old Sep 13, 2010 | 05:35 PM
Former User's Avatar
Default Re: B16 misfire
Any CEL codes?
Old Sep 13, 2010 | 05:43 PM
JDMFEVER's Avatar
No codes
Old Sep 13, 2010 | 05:48 PM
When the A/C is on, does the condenser fan run? Did you recently have any A/C work done?
Old Sep 13, 2010 | 06:13 PM
JDMFEVER's Avatar
Originally Posted by RonJ@HT
Any CEL codes?
No recent a/c work. Only distributor work has been done in the last month.
Old Sep 13, 2010 | 06:14 PM
Old Sep 13, 2010 | 06:16 PM
JDMFEVER's Avatar
Yes
Old Sep 13, 2010 | 06:22 PM
Hook up a manifold gauge set. You will likely find excess pressure on the high side. This could be caused by a system overcharged with refrigerant, air in the system, or a restriction that is preventing proper refrigerant flow in the system.
Old Sep 13, 2010 | 06:41 PM
JDMFEVER's Avatar
I'll try that but what about the rpm drops? Could it be the fitv that's dirty? I have and obd1 b16 from a del sol.
Old Sep 13, 2010 | 06:56 PM
I didn't think you had a low idle problem because you mentioned sputtering problems even up to 2500 rpm. When the A/C is not on, is the idle speed low?
High pressure in the A/C system would greatly increase engine load and drop the engine rpm.
Old Sep 14, 2010 | 05:36 AM
JDMFEVER's Avatar
Idle is fine with the a/c off. Except when the engine is cold the idle bounces from 1400 to 1800 until warm
BmoreEG
May 19, 2013 09:11 AM
JDMFEVER
Sep 14, 2010 01:12 PM
brownsEF
May 12, 2010 10:35 AM
gsxrnut03
21
Mar 14, 2009 09:05 PM
themex77
Aug 11, 2006 11:21 PM
