FT fully race built ls-vtecwith extras WILL TRADE!!! for nice turbo kit must see...
Old Sep 13, 2010 | 12:54 PM
Eviltek1989's Avatar
Default FT fully race built ls-vtecwith extras WILL TRADE!!! for nice turbo kit must see...
looking for a real nice turbo kit with tune ecu and all the goodies alot of money and time has been put into the motor and looking to get a great boost setup since i have a built b20b in need of a turbo kit motor will pay shipping and willing to travel to pick up swap will come with headers and brand new full catback exhaust...
1500 on swap almost a brand new baby doesnt smoke leak or anything idles real good from tune and it being put together right.
2 1/2 full brand new ace full catback exhaust
4-1 megan race headers
ls b18a block
build from alaniz dfr race shop in california
91 Ls Block
Bored .5 over
New 81.5mm ACR high compresion full race pistons
Pistons Diped n a protective coating to make them stronger will withstand high heat and rpm
New arp head studs
New new comet 3 layer head gasket
New golden eagle dowel pins
New gaskets from top to bottom
New 4-1 race headers
New 2 1/2 inch full race catback exhaust
New Nitric pistons rings
New ARP rod bolts..
New ls rods shotpeend
New Race bearings
Micropolished n balanced crankshaft
New Kings thrust Full Race Bearings
New main seal
p75 obd1 tuned and chipped ecu
redline 8500rpms/vtech hits at 4000 rpms
obd2 wireing harness
new performance lightend pully
All seals are brand new block was decked and cleaned before the build block was shaved for higher compression
2000 b16a full race head
built by alaniz dfr race shop in california
full race all angles port and polish also has coating over polish for flow test...flow test was real good by the way
all new seals and pins
new supertech valve guides
new supertech flat vaves
new supertech retainers
new supertech spring... very strong
supertech everythng no oem in it....
toda spec bs stage 2 cams
intake side bored .5 oversized for more air flow
walls where shaved down for better flow and low temps...
head was also polished and cleaned
new b16 dizzy
str high voume fuel rail
costum injector clips
b16 intake manifold
also there is a few more goodies that i havnt metioned so let me know if interested
this is all motor 12 sec set up fully built theres been alot of time and money into this looking complete turbo kit already tuned and chiped for trades.... serious buyer only will respond asap. 775-229-6486 ask for jose or text
Eviltek1989
Jun 29, 2010 03:46 AM
