b20/vtec integra=no vtec
hey guys im posting up for a friend. he has a 99 gsr integra with a b20b/b18c1 swap.
He bought the car how it is for a great deal from a dealership not knowing anytthing about it.
he brings it to me and says my vtec isnt working. So i checked the oil lines etc.coolant level,oil level,no check engine lights.. and then to the ecu. it has a p73 obd2 ecu for one.
anyways i took the vtec soleniod off and cleaned the screens and gaskets off. put it back together took it for a drive and it worked. on the way back to our car meet, he drove it and it didnt work. we let the car sit for 10 min. tryed again and it worked, then on the way back after turning around it didnt work????? im lost
only thing i can think of is loss of oil pressure, because it was kicking in late. .like around 6-6300 rpms. and with a skunk 2 I/M and a ITR ecu it should be around 5200 rpms
any suggestions???
any suggestions???
thats not it i did. after the car starts warms up..drive it.. hits vtec..slow down turn around in a parking lot..let it sit for a min. make another pull no vtec..every single time. every time he lets the car sit for a while then start it up hits vtec..then 2 min. later it doesnt. there for im thinking oil pressure??? idk confuses me
Oil pressure would be a Good thought...if it's not right at the time of engagement it won't hit, wont throw a CEL Light either (At least i've seen it happen). Have you tried using another ECU?
no i told him to find someone with a p72 just try it. and if thats the problem i told him to get a jumper harness and go the p28 route.
and to get a oil pressure gauge asap. its weird the car runs great!!! just no vtec all the time. and im sure it would be a pretty quick car. im just trying to help him out because he bought the car the way it is and hes only 17 so he knows nothing about honda's yet.
nope checked it for shorts for him and everything was good, vtec solenoid is good. just waiting for him to get a oil pressure gauge so i can narrow it down
too many reasons to even count
1. if it's a usdm p73 you need
a. cfs sensor
b. knock sensor
c. vtec solenoid with oil pressure
2. if it's a jdm p73 you need
1. knock sensor
in all cases you need the wiring strung for the correct sensor
one more thing, a p73 only works on a 1.8L engine with itr cams and a single runner manifold
you do not have this thus you have the wrong ecu for that engine.
a. cfs sensor
b. knock sensor
1. knock sensor
yea when he first got the car he showed me everything that was done. then told me vtec wasnt kicking in. so first thing i checked was what ecu...p73 everyone was like so what..i said well that wont work unless you have all of the above^^ he does have a skunk2 manifold..but as far as engine internals are im pretty sure there stock but i have no clue. he got the car from a dealship and they knew nothing about it. He hasnt got the title yet from them or anything i told him to tell the dealership he needs to speak to the previous owner about everything done.
only things i know are
b20b block
b18c p72 head
s2 cam gears
s2 manifold
aem fuel filter
golden eagle fuel rail
aero fpr
i/h/e
friday im going to his house to pull the valve cover off to see what cams. and pull the ecu to see which p73 it is. how can i tell if its usdm or jdm??
also where are the knock sensors located on a b20?
also is there a way to tell if its a gsr harness.
the car is originally a 99 ssbp gsr.
b20b block
b18c p72 head
s2 cam gears
s2 manifold
aem fuel filter
aero fpr
i/h/e
i'm not even sure if the b20 has a knock sensor that's compatible with the p73, it's disabled in many obd1 custom maps because people don't tap the blocks to fit the correct one.
when you look at the ecu you'll see p73-a02 or3 or 4 if it's usdm, jdm is p73-003 or 4
of all these p73-a02 is the most sought after
p73-003 and 4 are the easiest to get running since they don't require the usdm sensors or even need a post cat o2
all are wrong for any b20
I would look at the oil pan, make sure it's not dented inward. I had a similar problem, intermitant VTEC engagement and it turned out to be the oil pan.
As for the knock sensor, don't they make a sensor delete for that? I thought I heard of a device that tricks the ecu into thinking there is a sensor there....
Best bet on the ECU is to run a tuned unit. Crome, Uberdata, Hondata, whatever but get it set up properly!
alright ill tell my buddy what he needs to do. i told him to get the money to me and ill make sure he gets the right stuff. i was just gonna get a a 0bd2 to 0bd1 jumper harness and a p28. then have it tuned/chipped on crome. or s300
hey its not my car man hes got money!. well icalled him today he said he ordered a chipped p28 with jumper harness. He said he told the guy his motor and mod setup and they would tune it to those specs with a re burnable chip. so hopefully this works out for him
tuner shops constantly take advantage of idiots. which hondata they sell is only one place. the s300 has the biggest margin and the highest profit per sale. useful in some apps but overkill in many.
yea idk where he got this "pre tuned" ecu. i told him just to get stock p28 and i would base map it on crome i have the softwear. but he spent 290 dollars on this random ecu thats chipped with a jumper harness and a 2 step. probably ebay. whatever. Thats what happens when a 17 year old kid gets 6 grand and guys out and buys a bad *** ssbp gsr
flek
Feb 27, 2009 07:14 AM
showtymers619
Apr 14, 2004 11:00 PM
