b16head,wg,ic,injectors,sleved block,dizy,clutch,p28!!! >WA<
Old Sep 12, 2010 | 08:50 PM
runsfromdacops's Avatar
Default b16head,wg,ic,injectors,sleved block,dizy,clutch,p28!!! >WA<
so im tryign to sell al my **** befor i have to move.prices do not include shipping.
Im open to offers but don’t be a fool about
-b16 head 600$
came off a running motor, all parts had about 3-4k on them
the ports were "cleaned up"
s2 retainers
s2 dual valve springs
omni flat face valves
rocket motor sports M-21 cams 300$
i got them with a motor i bought but i ended up going bigger
these are suposed to be alittle more agresive then a jdm hype-R cams.
B16 dizzy125$
Small 4” inlet k&n filtter40$
str cam gears 40$
gsr cams 60k 40$
tial 40mm waste gate 5k miles 150$
with both flanges and I think a 11psi spring. If some one wants the dump tube they can have it if picked up or pay the extra shipping
ge vac block 20$
FAL fan and shroud 75$
The shroud is cut up and melted pretty bad but still worked great
Full race/ PWR single back door 300$
20x3x8”
Worked great I made 450 on this ic with out seeing retarted iats
Aasco motorsports alum. Fly wheel100$
4-5k on it, looks ****
Comp clutch stage5 pp 75$
4-5k as well
I don’t have the disc, don’t know where it went.
Golden eagle sleaved ls block 500$
84.5 might need to go to 85mm
The block throw a rod and was repaired/reweled and run (made 625) befor I got it. When I pulled the headstuds out one came out hard so it might need to be rethreaded
It had 4 scufed piston #2-3 were not bad but 1 and 4 were worse.
Macheing main caps
Good gsr crank 125$ sold
Golden eagle ls vtec kit 100$
Msd 1580cc injectors 200$
Work well but don’t idle very well,would be good for a track car or a car on e85
3” exh. No muffler with a 4” turn down tip 125$
Chipped p28 125$
-alex
425-260-4244
Old Sep 22, 2010 | 08:41 PM
Default Re: b16head,wg,ic,injectors,sleved block,dizy,clutch,p28!!! >WA<
ttt
Old Sep 23, 2010 | 12:26 PM
ttt
Old Sep 28, 2010 | 11:49 AM
obo ppl. dont be afread to make some offers
runsfromdacops
Northwest (Sales)
12
Apr 2, 2011 09:35 PM
rmcdaniels
Nov 22, 2005 04:24 PM
