Power windows help!!
I have a 1996 civic sedan. All my windows dont work except for one. They dont go down or up. The only one that is working is the one behind the driver side and the one behind the passenger side seems like it goes up but not down. I replaced all window fuses under dash and also replaced the 40A fuse under the hood. If any one can help me with this problem i would really appreciate it. Thanks
Check whether fuse 10 and 11 are blown and check whether the driver's and front passenger window motor work if you run a wire to them from the battery. For the rear windows, test the switches.
