Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Never seen this when changing my oil
Old Sep 12, 2010 | 06:07 AM
pippo's Avatar
Default Never seen this when changing my oil
Hi people,
I drained my oil in my civic, and let drain for 4 hours, only cuz I had to leave for a short trip and figured it can only benefit draining . Then, after the 4 hour drain, I unscrewed the filter expecting the usual drip/slop during the unscrewing, and no drip/slop......upon inspecting the inside of the filter, there was absolutely NO oil left!
It had been unusually long period between change this time, I figured about since March (Bad me), and maybe the silicone anti drain seal/valve in most filters broke down?? Could that be the only explanation?
Thanks!
Old Sep 12, 2010 | 09:20 AM
Pothole987's Avatar
Default Re: Never seen this when changing my oil
it could of actually drained down slowly.
Old Sep 12, 2010 | 11:58 AM
theineffable's Avatar
It should not have drained slowly. The anti drain back valve is bad, which is really bad for the engine because the engine will be starved of oil everytime it is started
Old Sep 12, 2010 | 12:00 PM
With the filter facing downwards, poke the silicone anti drain back valve to open it. Does more oil come out? If yes, the filter is fine and did it's job
Old Sep 13, 2010 | 03:34 PM
pippo's Avatar
Hmmm, good tip, ineffable. I didnt know that. Ill try it. Thanks!! (next time Ill replace sooner).
CHW2021
Apr 23, 2012 04:36 PM
qk_boosted_b17
Nov 3, 2010 01:15 PM
Iomega01
Mar 25, 2006 09:07 AM
skunk2finatic
Oct 28, 2004 10:05 PM
CW-ITR
Jun 18, 2004 03:57 PM
