Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
K&N Air Filter - K&N Intake System - K&N Breather Filters - And More!
Old Sep 12, 2010 | 12:51 AM
RedlineMotive's Avatar
Default K&N Air Filter - K&N Intake System - K&N Breather Filters - And More!
K&N Air/Fuel Monitor The KN Air Fuel Monitor is a precision instrument designed to help performance enthusiasts calibrate an optimum airfuel mixture ratio This device will work on carbureted injected supercharged or turb ...
K&N Apparel Dont let you KN pride stop at the Track Wear that pride on your Back ...
K&N Drop-In High-Flow Air Filter KN Replacement HighFlow Air Filters are The Original HighFlow Air FilterSince 1969 KN Engineering has been designing manufacturing and enhancing HighFlow Air Filters for the automotive and motorcycle ...
K&N Filter Accessories - Carbon Fiber Composites Leave it to KN to come up with products that have both cosmetic appeal as well as deliver outstanding performance KNs Carbon fiber composites have attractive cosmetic appeal and the outstanding stiffn ...
K&N Filter Accessories - Cleaning Products KN Filtercharger OilKN Air Filter Oil is the only oil specially formulated to work in combination with the cotton fabric in KN Filtercharger elements providing a superior air filtration system When us ...
K&N Filter Accessories - PreFilter PreChargerThe KN PreCharger is a specially designed filter wrap made to extend the service interval of your KN Filtercharger when used in very dusty conditions They are made from durable polyester mat ...
K&N Filter Accessories - Replacement Parts Need to replace a lost or broken piece of you KN Intake Kit or Filter Have a custom project in mind that requires KN parts Then look no further Available Replacement Parts Include Adaptors Clamps ...
K&N Filter Accessories - XStream Air Flow Top KN gives you the power youve been looking for with the new XStream Air Flow Top Not only does the XStream add filter area it actually redirects airflow inside the filter to pull in more air through th ...
K&N Fuel Filter Why limit KNs Filter Technology to just your intake KN Fuel Filters use the same high flow filter technology as the KN range of intakes and provide exactly what youd expect more of what you want and ...
K&N Intake Kit - 57i Performance Induction Kit As with every KN kit when you bolton a KN 57i Performance Induction Kit you will notice the difference the next time you drive your vehicle KN 57i Performance Induction Kits are a great way and in man ...
K&N Intake Kit - 77 Series High Performance Air Intake KN 77 Series High Performance Air Intake Kits for trucks and SUVs combine outstanding performance and underthehood style Many consumers will opt for the visual appeal of these kits The metallic finis ...
K&N Intake Kit - AirCharger High Performance Intake (63 Series) The KN AirCharger High Performance Intake 63 Series is a sister product to our the KN Series FIPK 57 Series The KN AirCharger High Performance Intakes are built for many different vehicles and repres ...
K&N Intake Kit - Apollo Universal Cold Air System (CIS) The KN Apollo CIS Cold Intake System is a universal cold air intake system incorporating a washablereusable KN HighFlow Air Filter The Apollos specially designed shape increases volumetric efficiency ...
K&N Intake Kit - Fuel Injection Performance Kits (FIPK) KN Fuel Injection Performance Kits FIPKs are built for many different vehicles and represent a dramatic improvement over a KN OE replacement filter alone they use only nonmetallic rotationally molded ...
K&N Intake Kit - Typhoon System Cold Air Built for performance and show the KN Typhoon Air Intake System is a freeflowing mandrelbent aluminum tube induction system designed to fit many sport compact performance vehicles Each kit is proven ...
K&N Intake Kit - Typhoon System Complete Cold Air Built for performance and show the KN Typhoon Air Intake System is a freeflowing mandrelbent aluminum tube induction system designed to fit many sport compact performance vehicles Each kit is proven o ...
K&N Intake Kit - Typhoon System Short Ram Built for performance and show the KN Typhoon Air Intake System is a freeflowing mandrelbent aluminum tube induction system designed to fit many sport compact performance vehicles Each kit is proven ...
K&N Performance Gold Oil Filter KN Performance Gold Oil Filters were originally developed for demanding auto race applications our premium automotive oil filter is rapidly becoming a favorite among consumers for its durability and e ...
K&N Promo Products Dress up your Garage or Office and show you KN support with the newest and best items from KN ...
K&N Roush Racing Glue Roush High Performance ClogFree Super Glue Roush High Performance ClogFree Super Glue has a patented delivery system that allows for precision application with no drips or clogs This delivery system a ...
K&N Universal Filter - Crankcase Vent Filters KN Crankcase Vent Filters consist of a one piece design with a rubber or chrome top Filters are available as ClampOn or PushIn style mounting and can be clamped directly to metal or plastic tubing or ...
K&N Universal Filter - Custom 66 Assembly Custom 66 air cleaner assemblies from KN are designed for use with any engine that uses a round element air cleaner housing They incorporate our famous KN Air Filters and provide serious air flow Ava ...
K&N Universal Filter - Custom Air Filter Assembly KN Custom Air Filter Assemblies are designed with the racer in mind They incorporate good looks as well as the superior air flow that you expect from KN KN Custom Air Filter Assemblies are designed f ...
K&N Universal Filter - Industrial Filters KN manufactures many direct replacement elements for small industrial engines utility lawn and garden units air compressors generators chain saws etc Let KN add new life to your reliable work engine ...
K&N Universal Filter - Marine Flame Arrestor The KN Flame Arrestor makes the worlds leading airfiltration technology available for marine engine use For the first time boat owners can experience the increased horsepower and engine protection pr ...
K&N Universal Filter - Oval Dual Flange Filter KNs Universal Air Filters are designed and manufactured for a wide variety of applications Regardless of the angle offset diameter of the air intake there is a KN Universal air filter for your equipme ...
K&N Universal Filter - Oval Filter KNs Universal Air Filters are designed and manufactured for a wide variety of applications Regardless of the angle offset diameter of the air intake there is a KN Universal air filter for your equipme ...
K&N Universal Filter - Round Cone Filter KNs Universal Air Filters are designed and manufactured for a wide variety of applications Regardless of the angle offset diameter of the air intake there is a KN Universal air filter for your equipme ...
K&N Universal Filter - Round Straight Filter KNs Universal Air Filters are designed and manufactured for a wide variety of applications Regardless of the angle offset diameter of the air intake there is a KN Universal air filter for your equipme ...
K&N Universal Filter - Unique/Special Application Filter KNs Universal Air Filters are designed and manufactured for a wide variety of applications Regardless of the angle offset diameter of the air intake there is a KN Universal air filter for your equipme ...
K&N Universal Filter - Velocity Stack Filters KN Velocity Stack Filters are designed to fit with cut velocity stacks or straight pieces of exhaust tubing Rubber filter bases come with molded in velocity stack type radius and step for smooth bore ...
K&N Universal Plenum CUSTOM PLENUMCast aluminum plenum beautifully finished with black powder coating and natural aluminum highlights The plenum is designed to fit most American 4 barrel carb that have a 518 flange Also w ...
Old Sep 13, 2010 | 08:59 AM
Default Re: K&N Air Filter - K&N Intake System - K&N Breather Filters - And More!
Bump it up for a Monday, thanks Honda-Tech!
Old Sep 14, 2010 | 10:34 AM
Thanks for your inquiries everyone!
Old Sep 14, 2010 | 03:33 PM
We received a big shipment today of part numbers, thanks for your interest!
Old Sep 15, 2010 | 04:09 PM
Bump it up for a Wednesday
Old Sep 16, 2010 | 03:15 PM
bump it up guys!
Old Sep 17, 2010 | 05:59 PM
bump it up for the weekend!
Old Sep 18, 2010 | 09:50 PM
Bump it up for a Saturday night!
Old Sep 21, 2010 | 10:44 AM
Thanks for all of your PMs guys!
Old Sep 23, 2010 | 11:31 AM
ttt
Old Sep 27, 2010 | 11:02 AM
bump
Old Sep 27, 2010 | 09:10 PM
sayanything's Avatar
how much for a K&N filter for an AEM V2 cold air on a b18c1, 01 OBD2 3dr GSR? shipped to 89107?
cottonfamily05
Aug 21, 2005 11:08 AM
RemerLex11
Aug 4, 2004 08:18 AM
KiNG $h!t
Mar 16, 2004 06:34 AM
5thgenlude101
Aug 28, 2003 01:43 PM
2005 TSX
Mar 27, 2002 12:00 AM
