cut through harness, now car wont start
so as i was cutting out my frame, i managed to slice through the plug that connects in front of the resistor box by the clutch fluid resovoir. i sourced a new plug and wired up everything but now it wont start. engine turns over but does not start. checked my wiring and soldered everything properly. any ideas?
You made a mistake during the re-wiring process. Or, you caused a fuse to blow due to a short circuit during the " boo boo " process. Some wires are " Hot at all times ".
b16hatch66
Apr 14, 2005 12:29 PM
