FS: LS head, Centerforce clutch, Turbo manifold, more
Old Sep 11, 2010 | 06:14 PM
Hybrid96EK's Avatar
Default FS: LS head, Centerforce clutch, Turbo manifold, more
I've got several items I would like to sell in order to clear up some space in the garage. Open to all offers, please be resonable.
96 Integra LS head. Complete with intake manifold, no dist. Cams, cam caps, bolts, valve cover (earlier style), headbolts, etc. Came off a running engine, I see no problems with it. Could use a cleaning, thats it. Asking only $50!
Centerforce B series hydraulic clutch. Clutch and pressure plate, dual friction style which is EXCELLENT for use with force induction and high HP applications. Lots of meat left, very good shape. Almost new! I no longer have B series, so no use for it. Asking $50!
Revhard turbo manifold. Cast iron, no cracks, not welded up, not warped. Great shape. I cleaned it up and put a fresh coat of high temp VHT flat black on it. Never used it, sold all my B series items. I paid $80 used, asking $40. Uses 38mm wastegate.
D16Z6 bottom end. Realatively complete. Missing the crank. Cylinder walls in good shape. Used the crank for another project, didn't have any spun bearings or anything like that. $20 and the whole thing is yours. I would reccomend a rebuild, but the engine was running at the time it was pulled/parted.
Two 99-00 SI rims PAINTED white. Not powder coated. Some chips. Not curbed, not bent. Great as a spare set, drag wheels, whatever. Strip the paint and polish them, powdercoat them, or ?????. Asking $40 for BOTH rims! Can't beat that can you?
kennybuilt teg
Oct 19, 2013 08:39 PM
en00be
Jul 25, 2009 10:00 PM
Integra_drk
Mar 4, 2007 07:43 PM
JadeGreenEF9
Feb 6, 2007 04:07 PM
adamponce
Apr 11, 2004 07:03 AM
