ls 5th gear hydro b16 trans
Hey wondering if anyone could help with some info. working on a DD H2B setup for my EG. Trans is a JDM 92-95 2nd gen b16A Hydraulic LSD unit. Would like to do the longer 5th gear. As far as I understand, when doing this swap in a first gen B16 cable trans you use the main and countershaft 5th gears from a 90-91 integra, which swap over directly. Now for a Hydro trans do I use the same gears? Or perhaps the 92-93 gears? I know they are different. Or maybe the 5th gears from a DC integra would be a better choice. I will be having a transmission shop do the work I just want to make sure I get that right parts. Info appreciated.
*Boostwerks*
19
Nov 5, 2005 01:59 PM
