resetting vafc 2
can someone please walk me through the steps to reset an apexi vafc 2?
bout one with harness for my s2k but was tuned for an ap2 an im running an ap1. i would like to reset it back to stock so i can have it hooked up so i can take it to get tuned next week. thanks guys!
As far as i know it's reset by entering .3 of the main menu, then scroll all the way down to .9 or "initialize" click in the center button of the roller dial or simply press to the right of the center switch to go into the next menu from there. You will be ask Yes or No select Yes using the roller dial then press to the center button to the right one more time to bring you right back to the previous menu indicating a reset has been performed. I usually do this 4 times in a row after resetting the ECU then disconnect the battery neg with all power and key on for 30 min for further piece of mind.
Hope this helps.
Hope this helps.
Blazeone
May 21, 2003 07:10 AM
