non tach cluster, what do i need to get for a cluster with a tach?
Old Sep 11, 2010 | 01:32 PM
V.MoMO's Avatar
Post non tach cluster, what do i need to get for a cluster with a tach?
i currently have this cluster and want to get a cluster with a tach
but i noticed that for the clusters with a tach there's a connection right there
DO I HAVE TO GET THE WIRING FOR THAT CONNECTION AND ANYTHING ELSE THAT GOES WITH IT?
Old Sep 11, 2010 | 08:27 PM
V.MoMO's Avatar
Default Re: non tach cluster, what do i need to get for a cluster with a tach?
this is what i want....
and thats what i mean....
PLEASE PEOPLE SUM ADVICE, HELP!!!!
Old Sep 11, 2010 | 08:29 PM
Jas9848's Avatar
From what I've seen clusters are plug and play and will work fine as long as it's the similar chassis. I put a EX/SI cluster in a DX/CX that did not have a tach on the cluster and it worked perfect. Not sure what that 2 pin connector is for on an EK cluster though. Try it out and see if it works.
Old Sep 11, 2010 | 08:38 PM
V.MoMO's Avatar
Post Re: non tach cluster, what do i need to get for a cluster with a tach?
well thats the problem, i dont have the cluster yet and i dont want to blow money on it and not have it work. so thanks much and hopefully other people will enlighten the subject
Old Sep 11, 2010 | 09:13 PM
megomaniac's Avatar
If i remember correctly , that connector your worrying about has nothing todo with the rpm signal wire. look up the wiring diagram, find the rpm signal wire ( tach wire) i think it's just one blue or green wire, don't remember but i'm fairly sure its on the connector on the 45 degree, once you have located the wire for the tach you'll know what plug it is on....
Old Sep 11, 2010 | 09:17 PM
megomaniac's Avatar
b8 blue wire, took 2 seconds on google
Old Sep 11, 2010 | 09:40 PM
V.MoMO's Avatar
megomaniac, good thing i have a repair manual laying around, with that said i think my dilema is over , thanks again
Old Sep 12, 2010 | 08:44 AM
HondaPartsHero's Avatar
Technical Hero
you don't need to add any wiring, just get a 96-00 manual or automatic cluster that has a tach, plug, play, done. I just did this in my 96 DX, used a 97 EX auto cluster with no problems.
gotgohan
Jul 12, 2009 11:35 AM
triple5soul8781
Aug 7, 2008 05:46 AM
DenzComp
May 6, 2007 11:27 AM
Frito-Ray
Feb 15, 2005 12:12 AM
89DXDann
Jun 4, 2004 11:38 PM
