Fitting 15x8 +15 xxr?
the only major problem ull really have is camber wear and rubbage. role ur fenders as much as u can to die down the rubbage. but those wheels would look hot tho. good luck
i have been running 15 * 7 and the offset was +37 and they rubbed on my camber arms at the back. if i went round a hard corner they would make a horrible scrapping noise.
15*8 haha good luck with that one.
yea sportmax xxr whatever they are today, its not that they dont look good, they are crap in general.. The bend easily, rust easily, don't fit properly, they are about 3-5mm off on the hub bore size to what it is supposed to be. the build of these wheels is by far the worst i have ever seen in a set of wheels.
In My Opinion Xxr Deep dish Are BAd *** All You Need Is To Roll Your Fenders nd Camber kit. Ok xxr Bend? You Swear Like Every Other Brand Thats NOt Xxr DOesnt Bend Or BReak! i Say Go For It! POst Pics!
buy the wheels and rock the **** out of them. but i would get +20 offset and run a 215/45/15 tire!. and you will need about 2 degrees of camber if your slammed/dumped
put them on the car then modify the car so the changes can't be undone, then you will be happy
Wow, I'm amazed that the whole hellaflush fad seems to be dying out here all of a sudden.
That's good. It needed to die. Hondas are not VeeDubs, yo.
help would greatly be appriciated on whatsize tires to put on the xxr 002 15x7 0 offset im a noob lol and just trying to get my car to what I think looks good i have skunk 2 camber kits and omni power suspension i know ima have to roll my fenders im just curious to what size tire to get to prevent as much scubbing as possible thanks alot....
from your sig i assume you have a 96-00 hatch so depending on the year and trim you can follow the reccomended tire sizes below:
For a CRX, del sol, del sol Si, or pre-'96 Civic, the following sizes are usually best:
13" - 175/70-13
14" - 185/60-14, 195/55-14
15" - 195/50-15
16" - 205/40-16, 195/45-16
For an Integra, del sol VTEC, or '97-00 Civic, the following sizes are usually best:
14" - 185/65-14, 195/60-14
15" - 195/55/15, 205/50-15
16" - 205/45-16 would be the best size but 215/45-16 will work also but only if your car isnt too low and if the wheel offsets aren't too low.
17" - 205/40/17
Then start a different thread just for you, not thread jack another guys.
You SHOULD be runing 205-50-15, but i honestly doubt it will clear without tons of camber and rolled fenders. It also depends on how low you are.
Ok like i previously said " ima a noob " meaning to this site and EVERYWHERE i look it is a question like mine and it turnes out to be people **** talking others. i made an account to find out what size tires i need to run because none of the others questions were answered i have no clue on tire size or anything or i wouldnt have came here... now you say i "SHOULD" run those but but i will have to have tons of camber witch is fine i suppose but i would like to know the absolute smallest size i can go with those rims to prevent as much cambering, scrubbing that i can.... and as far as me thread jacking another guys and not starting my own "im a noob" idk how or i would have so im sorry if you could give me the little bit of info i have asked for it would be greatly appreciated....
