H2B knocking, oil lights and dieing.....HeLp
THESE WERE THE PROBLEMS:
the motor is being weird, when i start it up its fine until its fully warmed up. when it is fully warmed up my oil light flickers & motor dies if i dont give it gas.
i do have some what a leaking head gasket but its not that bad. and good oil level too.
=====and its a new oil pump too, maybe the sending unit ?
i jus finaly finished the swap and this is what its doing
BUT NOW I HAVE BIGGGGGGGGGGER PROBLEMS:
TODAY 9-10-2010
(ive only put 10 miles test driving the car for the past 3 months)
sounds like it knocking........why does it sound like this now and it didnt the first 10 miles?????? i didnt really floor it cause i wanted it to break in. Can this noise be something else????????
i bought this motor from a guy that bought this motor from someone else and he wasent even sure if it ran. but can anyone pass up a h22a4 for 500$?
any ideas>?
thanks in advanced
TODAY 9-10-2010
any ideas>?
thanks in advanced
^^^Shouldn't be.
But sadly enough I think he's right...
On a high note, you can avoid having to deal with getting a rehone on those Miffed up cylinder walls of yours if you just....Cop my Jdm h22 bare block....
BOYAH.
my oil pump is new
good oil level
oil light only flickers when fully warmed then it dies.
when i do give it lil gas, the oil light fades away
and how mcuh fr that h22 block EXTRABLACKREX??
good oil level
Or it may be that the rod bearings inside the block may have been oversize which results in low oil pressure. Bearings will need to be the correct size to build up oil pressure.
OP, also, try changing your oil filter because it may be a bad one to cause a knock. I've used a new oil filter(bad one) before and the motor started knocking til we swapped it out for another new one.
PoMoNa_909_eM2
Honda Civic (2001 - 2005)
15
Oct 13, 2010 07:13 PM
H2b-eghatch
Sep 11, 2010 06:57 AM
dsav4shawn
Oct 7, 2006 03:46 PM
96hb
Sep 14, 2003 07:57 PM
