I believe my clutch is going bad. Can anyone confirm or tell me what is wrong. Thanks
Well lets see today going to work I wasn't able to shift at all when the rpms went over 3500. If I reved it to 4500 or anything above 4000 the shifter would just jam and if I tried to force it a little bit it would just grind. It did the same thing coming home. I have about a 15 minute commute. My clutch pedal feels like it is going to the floor a little easier than usual to. The car has about 170,000 miles on it and was running strong with very few problems up until this point. I bought the car with 165,000 on it. I have no idea how long its been since the clutch was changed or if it has ever been changed. 1998 Gsr if that makes any difference. Thanks for any help.
I dont know the proper procedure for it so that is the only thing holding me back on doing it. I have bled brakes many times but I have never done a clutch. Thanks for the suggestion though.
Check up under the dash board and see if the clutch master cylinder is leaking. It sounds more like a hydraulic issue at this point judging from your description.
if you have money i'd go with a exedy stage 1 and a flywheel. but if you can't afford a or have a light flywheel take the stock one to a machine shop to be resurfaced for 40 bucks
If it ends up being the clutch that was my plan but i am keeping the stock flywheel because i personally do not like light flywheels. the rpms drop to fast.
Just some info for those wondering what was wrong. Although I doubt anyone was. But any way there was quite a bit of air in the system so after I bled it that helped it a little bit but it was still pretty bad. Then my older brother drove it and he said the clutch was pretty much shot so I need to get one. Thanks to everyone for the help. Hopefully this will help someone else out with the same problem one day.
Clutch going bad or something?? Just had both cylinders replaced and no leaks this time...??? what t
just4747
Jan 25, 2005 08:33 PM
