1998 Accord LX 4Door - NO power locks and No Power windows (Passenger side only?!)
Like the title says: All of the sudden my girlfriends car has no power locks (The alarm wont unlock the car and pushing the switch on the door does nothing) You have to either pull up/down the pin manually or use a key...I can deal with that, but at the same time as the locks the power windows died ONLY on the passenger side. Drivers side front and rear goes up and down fine.
They both are dead-dead. As in, there is no whining, no clicking, nothing. You press the switch and Nothing happens for both. no sounds, no movement, nada. Any thoughts???? I've never come across this before...
I'm thinking it's gotta be the aftermarket alarm/remote start combo has a loose wire or is bad? The 20A fuse on the pass side seems fine (Locks).
Is it possable for a alarm to cause something like this? It's been installed and working fine for years....
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Make sure there is power going into the door. Does the passenger speaker work? Make sure the passenger plug for the door to car has not come unpluged. The window and door locks are on there own circuit. I really doubt its the alarm. Alarms get the blame for everything.
Thanks for the reply - found the fix over in the accord forum.
If anyone else has these symptoms, here is the fix:
https://honda-tech.com/forums/showth...t=wiper+switch
Thanks again to everyone who helped
I would check the wiring harness running between the dash and the door. I had similar issues with my 95 Civic EX and it was a shorted out wire in the harness.
Tonyl507
Sep 11, 2010 10:18 AM
tvoiswired
Jun 5, 2010 08:58 AM
nowind
Audio / Security / Video
Feb 22, 2007 02:24 PM
