1998 Accord LX 4Door - NO power locks and No Power windows (Passenger side only?!)
Like the title says: All of the sudden my girlfriends car has no power locks (The alarm wont unlock the car and pushing the switch on the door does nothing) You have to either pull up/down the pin manually or use a key...I can deal with that, but at the same time as the locks the power windows died ONLY on the passenger side. Drivers side front and rear goes up and down fine.
They both are dead-dead. As in, there is no whining, no clicking, nothing. You press the switch and Nothing happens for both. no sounds, no movement, nada. Any thoughts???? I've never come across this before...
I'm thinking it's gotta be the aftermarket alarm/remote start combo has a loose wire or is bad? The 20A fuse on the pass side seems fine (Locks).
It may have something to do with multiplex control unit in the driver's side door, see link:
http://www.tegger.com/hondafaq/tsb/accord/x98-071e.pdf
Does the pass window work from "its" switch. There is a reset procedure for the multiplex...I'll dig it up "if" the pass window works from the pass side switch.
The reset has something to do with putting the intermit. wiper in the middle position and starting the car...strange but it worked.
EDIT: found it in the search...https://honda-tech.com/forums/showth...t=wiper+switch
Tonyl507
Audio / Security / Video
May 15, 2011 07:07 AM
nowind
Feb 22, 2007 02:24 PM
