H2B SOUNDS LIKES IT KNOCK AFTER FIRST 10 MILES....HELP
Old Sep 10, 2010 | 09:24 PM
H2b-eghatch's Avatar
Default H2B SOUNDS LIKES IT KNOCK AFTER FIRST 10 MILES....HELP
THESE WERE THE PROBLEMS:
the motor is being weird, when i start it up its fine until its fully warmed up. when it is fully warmed up my oil light flickers & motor dies if i dont give it gas.
i do have some what a leaking head gasket but its not that bad. and good oil level too.
=====and its a new oil pump too, maybe the sending unit ?
i jus finaly finished the swap and this is what its doing
BUT NOW I HAVE BIGGGGGGGGGGER PROBLEMS:
TODAY 9-10-2010
(IVE ONLY PUT 10 MILES TEST DRIVING THE CAR FOR THE PAST 3 MONTHS)
SOUNDS LIKE ITS KNOCKING........WHY DOES IT SOUND LIKE ITS KNOCK NOW BUT IT DIDNT THE FIRST 10 MILES?????? IVE NEVER FLOORED IT CAUSE I WANTED IT TO BREAK IN....CAN THAT NOISE BE SOMETHING ELSE????????
i bought this motor from a guy that bought this motor from someone else and he wasent even sure if it ran. but can anyone pass up a h22a4 for 500$?
any ideas>?
thanks in advanced
Old Sep 10, 2010 | 09:31 PM
miamijdmcoupe524's Avatar
Default Re: H2B SOUNDS LIKES IT KNOCK AFTER FIRST 10 MILES....HELP
I would guess the sending unit yes. Did you check the bearing in the block? Usually you want to fully inspect the motor before its installed. Check the valve clearance too
Old Sep 10, 2010 | 09:53 PM
dud ima newbie. this is my first motor swap
will check all the above
& will update
Old Sep 11, 2010 | 06:57 AM
vinuneuro's Avatar
Make a new thread without all caps title and post.
ritz7
50
May 29, 2012 10:18 AM
H2b-eghatch
Sep 12, 2010 05:50 PM
H2b-eghatch
Sep 11, 2010 08:13 PM
Honda-ls-hatch
May 4, 2010 07:13 AM
dump3deg6
Apr 6, 2009 08:10 PM
