94 ex sleeper
Old Sep 10, 2010 | 08:36 PM
redskull1944's Avatar
Default 94 ex sleeper
has anyone seen this in honda tuning mag? pretty clean it's what I want to do with an integra or civic sedan when I get back to the states
http://www.hondatuningmagazine.com/f..._ex/index.html
Old Sep 11, 2010 | 07:20 PM
Default Re: 94 ex sleeper
does the owner post on ht? any more pics avail?
Old Sep 11, 2010 | 07:42 PM
GhostAccord's Avatar
Send a PM to Extralargenog
He still comes on here and comments/helps out once and a while.
r e a l h o m e m a d e t u r b o . c o m is where you will find him most frequently.
Old Sep 11, 2010 | 08:00 PM
he has the cleansest ride I have seen in a long time and to top it off the stock USDM build makes it much classier and well designed
Old Sep 11, 2010 | 08:19 PM
Yes sir, it is a clean looking sleeper for sure.
Old Sep 11, 2010 | 10:13 PM
I like your build as well can't wait to see the finished product. btw do you have any more detailed info on your over the plug individual coils, so I can use it on my b16 build?
Old Sep 12, 2010 | 09:16 AM
Thank you.
Actually the COP setup for use with a chipped Honda ECU is still in the R&D phase. (not dead) I've been researching a few different DIS systems to see if there is a way they will communicate. Also to find a way how to set them up. If your looking for a sure fire thing look into the AEM EMS, EPM & Pencil coil setup.
Or the cheaper way would be MegaSquirt with a cam (TDC) & crank trigger & pencil coils. My current setup has been switched to use the MegaSquirt III EMS.
Old Sep 12, 2010 | 03:09 PM
yeah I was looking at the AEM system but I would rather just do a regular ol chipped ecu and avoid a piggyback on top of that. right now I have a evo III dual coil system I grabbed at a junkyard I was going to use the dizzy internals inside a b series housing and make a harness over to the cop's that I was going to grab off a 300z fairlady but I don't know if that will work and I will be stuck with the dual coils instead. Could you chip a fit ecu or a k series to run a b series or in your case f for the cop setup?
Old Sep 12, 2010 | 04:31 PM
Other than the Hondata K-Pro I don't know of any K series tuning options. For the cost of a K pro & tune I'm sure you could do the complete AEM COP setup cheaper. The AEM is not a piggyback. It is a complete stand alone engine management system. You throw away your Honda ECU and run the AEM unit.
Old Sep 13, 2010 | 01:00 AM
hmmmm the aem cop setup sounds appealing
Old Sep 13, 2010 | 04:14 AM
nus_dogg's Avatar
I've seen this from another site. It's dope!
samger2
May 3, 2018 03:29 PM
dtec-vtec
Feb 8, 2006 10:39 AM
Junkiii Ek
Jan 24, 2006 08:01 PM
UnrealSpeed
21
Aug 18, 2001 07:16 PM
