Need advice on rear disk conversion nd engine
I have a 95 honda civic coupe ex with 150k body is kind of run down but runs good i recently changed the drums and wheel bearings i was wondering what would be a good rear disk conversion witch wouldnt give me alot of trouble to change. also how can i make my car faster with out costing me too much i have a d16z6 engine tanx
rear disc conversion? If you're saying that you have a '95 Civic EX model then it should be equipped with factory rear discs brake instead of drums. Now unless the previous owner (assuming you're not the original) swapped out with drums brake.
The other question is, are you sure you have an EX model Coupe? sunroof? power windows/lock/mirrors?
true not all of them had rear disks, if you want rear disks, you cant snag a set from the fallowing cars,
any 92-95 civic inc. 4 door ex's
The Del Sol SI Vtec (must use ex disk brake e-brake cables)
Every 94-01 Integra.
99-00 civic SI
If you do swap them out you also have to change out the prop. valve for a 40/40 valve. For power i'ed put together a simple T25 turbo set up.
99-00 civic SI
IT'S ME DAVID
Jul 26, 2005 10:17 PM
Neutex22
Jan 17, 2005 10:32 AM
