UGEO +factory O2
Old Sep 10, 2010 | 07:17 PM
frenzyh22's Avatar
Default UGEO +factory O2
Hi , I am just looking on some info on O2 sensors, i am in the process of finishing my f22b2 turbo setup and would like to know if I need to use the factory o2 along with the wideband before i weld in another o2 bung. my setup is as follows:
95 Accord f22b2 non-vtec
rebuilt cyl head
arp studs
new cap, rotor, plugs, wires ( using stock replacment ngk iridums)
obx mystery turbo, (brand new) think its a .63 ar with water cooling
obx ramhorn manifold
tial external wategate 7. ? spring
3'' down pipe with no cat, DNA muffler/resinator
moroso oil pan
prodrive oil pump with new OEM honda housing
huge external oil cooler
pwr civic half rad with a FAL fan
ACT 9lb flywheel
clutchmasters stg. 3 clutch
ultra rare M2Z4 JDM h22 LSD transmisson
new axles
omni power 70mm Throttlebody with custom tapered spacer/adaptor
greddy type RZ BOV
2.5'' intercooler piping
Stock block and internals
moroso breather can
ELECTRONICS:
Hondata S300 OBD1 Vtec ecu ( bought the vtec ecu for future upgrades)
AEM UGEO wideband guage/sensor
omni power 3 bar map
oil pressure guage
boost guage
oddessey 680 battery
venom 550cc injectors (still using factory resistor box)
Walbro 255 high pressure version
stock fuel regulator
Hondata PWM boost control solenoid
Any info would be great, Thanks!
Old Sep 10, 2010 | 07:32 PM
SDHonda153's Avatar
Default Re: UGEO +factory O2
Since you using Hondata S300, then no, you don't need your factory O2. You can just put your wideband in the same bung and configure the Hondata to disable the factory O2 heater and to use your wideband for closed loop instead of your narrow band. Just make sure to hook your wideband into your ECU. With the AEM that would be the white wire coming off of the wideband.
Old Sep 10, 2010 | 08:07 PM
frenzyh22's Avatar
Great info thanks alot!
jdmludeaz
Apr 8, 2006 03:09 AM
A.E Motoring
14
Aug 28, 2005 04:54 PM
arjusmc
Jan 14, 2004 01:45 PM
ScottEK
Aug 8, 2003 06:58 PM
Quick 200k Mile Motor
Sep 13, 2002 06:19 AM
