NEED IMEDIATE STRUT HELP!! Hex fitting at top of strut is stripped
Old Sep 10, 2010 | 01:45 PM
rollinhonda3's Avatar
Default NEED IMEDIATE STRUT HELP!! Hex fitting at top of strut is stripped
ok so i went to lower my 96 civic sedan today and i pulled the front left strut out and compressed the spring then went to remove the bolt to take the top off and the allen wrench part is completely rounded out to where to wrench or nothing will grip in and i dont have the money to go pick up a new strut specially just because of that lil part being rounded out any help ASAP woud be greatly appreciated!
Old Sep 10, 2010 | 01:54 PM
lome1232's Avatar
Default Re: NEED IMEDIATE STRUT HELP!! Hex fitting at top of strut is stripped
Tap it
Old Sep 10, 2010 | 02:02 PM
please explain in how to do this and what i need to do it!
Old Sep 10, 2010 | 02:53 PM
D16SiHatch's Avatar
had this happen to me and absolutely nothing i tried worked. smashed ever larger allen fittings in and they just kept stripping out. ended up taking it to a buddy who had to heat it with an oxy acetylene torch and then hit it with an impact. destroyed the other strut and i ended up replacing it anyway.
Old Sep 10, 2010 | 02:58 PM
i had no problem getting the strut out or nothing like that just that god damn hex fitting stripped out and i dont see the point of replacing a perfectly good strut just because of that there has to be a way around this!
Old Sep 10, 2010 | 04:10 PM
grumblemarc's Avatar
The Grumpiest
Vice grips. Worked for me.
Old Sep 10, 2010 | 07:48 PM
blown_ss's Avatar
this! you can put them through the spring and make them as tight as you can. i've done it that way plenty of times.
Old Sep 10, 2010 | 10:57 PM
D16SiHatch's Avatar
i did the vice grip method one one of the struts, and this subsequently caused the seal to fail and the strut to blow.
Old Sep 10, 2010 | 11:47 PM
thumper64's Avatar
if you do it at the very top where it won't go into the shock body, it works.
I have used an impact wrench before. Hold the tophat in a vice and hit it with an impact.
Old Sep 11, 2010 | 11:36 AM
D16SiHatch's Avatar
yea unfortunately my friend who was working on it didn't apply the grips at the top
DanG0r3
Apr 13, 2010 09:51 PM
koldkustoms
Dec 4, 2007 05:46 PM
nc-rsx-s
Aug 17, 2002 03:51 PM
