Wont start after changing timing belt
Old Sep 10, 2010 | 10:10 AM
danitoxgc's Avatar
Default Wont start after changing timing belt
i just change the timing belt of my prelude 2000 H22A4 but now that i put everything back in place it just dont start, feels like if does not have fuel but i checked filter, fuel pump and fuses.
i changed the belt because it got ripped, do you think that the valves suffered any damage?
i use the diagram from this link.
https://honda-tech.com/forums/honda-prelude-4/01-prelude-timing-belt-install-2591869/
really helpfull BTW.
Old Sep 10, 2010 | 11:08 AM
Prelude209's Avatar
Default Re: Wont start after changing timing belt
Im not sure if it can be the valves. how did it rip? did you try starting it or it ripped and you turned it off?
Old Sep 10, 2010 | 11:34 AM
SD_BB2's Avatar
did you put your battery back? lol simple stuff like that can be forgotten haha :p
Old Sep 10, 2010 | 12:34 PM
danitoxgc's Avatar
lol, it got ripped while i was driving, and i had to tow it to my house.
Old Sep 10, 2010 | 01:00 PM
lude98SH's Avatar
Do a compression and leakdown test.
Old Sep 10, 2010 | 01:35 PM
Rdriver's Avatar
I would check back over the timing marks, and firing order.
Old Sep 15, 2010 | 12:50 PM
Saukarji's Avatar
Any resolution to the issue? Did the car start? I have a similar issue which I will post shortly.
Old Sep 15, 2010 | 12:55 PM
1GPlusSH's Avatar
timing belt teeth being off usually seems like a fuel problem. i know it's not as easy putting on a new belt as it is marking an old one and putting it back on exactly right.
if you weren't in vtec, i wouldn't worry about jacked up valves. it's still worth doing checks, but don't stress over it until you get your numbers.
Old Sep 15, 2010 | 12:58 PM
1GPlusSH's Avatar
oh, and have a friend look at your car. you may be looking right at something obvious and not seeing it.
check to make sure that all your sensors are hooked up. check your grounds.throwing any codes?
Old Sep 16, 2010 | 12:40 PM
danitoxgc's Avatar
problem solved well it wasnt a big issue, i checked before and i had spark but apparently it wasnt on time so the guy just adjusted the distributor and it worked perfectly.
doc500
Apr 13, 2012 05:52 PM
JCracer723
Aug 19, 2007 01:38 AM
95dc2gsr
Apr 23, 2007 05:50 PM
DaKINE-Ek
13
Aug 15, 2006 10:57 AM
Dancing is Forbidden
Aug 27, 2005 11:47 PM
