Interchangeable radiators 99 civic si??
Old Sep 9, 2010 | 11:16 PM
aquito's Avatar
Default Interchangeable radiators ?
Thanks
Old Sep 9, 2010 | 11:47 PM
300whpej's Avatar
Default Re: Interchangeable radiators 99 civic si??
a half size, dual core radiator is what you need. if youre buying one new from an auto parts store, the part number is the same for all 92-00 civics, whether they are auto or 5spd (i ran around all day confirming this). there are plenty of good aftermarket radiators, which are aluminum, and usually dual/triple core, but really expensive if you are using this for your DD. if you are buying a used radiator, i would strongly suggest finding one thats known to be good from a 99-00 si, or a cheap, leak free aluminum one.
Old Sep 9, 2010 | 11:51 PM
SeanK325's Avatar
i found a dual core all-aluminum radiator for 130. Which was only 50 more than what any auto parts retailer wanted. realized it was overkill for a D motor and gave it to my bro for his EM1 project. mishimoto is a good brand, but expensive. you don't necessarily have to run an expensive radiator like that. what kind of motor do you have?
Old Sep 10, 2010 | 01:32 PM
aquito's Avatar
Ok thanks for the help guys..and I'm running a stock b16a2
Old Sep 10, 2010 | 01:37 PM
94EG8's Avatar
Seagull Management
'99 - '00 Si and '94 - '97 Del Sol VTEC rads have larger water necks for larger B-series hoses, you can use a normal civic rad but you will need to use adjustable gear style hose clamps.
Old Sep 10, 2010 | 01:50 PM
Deetz's Avatar
Crazy Honda Guy
Correct, and this is what you want if going oem
This is "only" true for D series engines.....as mentioned above, the Si and Del Sol DOHC model rads are better...both dual core, and larger water necks to accomedate the b series rad hoses
Old Sep 10, 2010 | 02:58 PM
300whpej's Avatar
surprisingly you are wrong. i was baffled about this because they all have the trans cooler lines also.
95 honda civic dx part number 432352
http://www.autozone.com/autozone/par.../N-j1i35Z9pdak
00 honda civic si part number
432352
http://www.autozone.com/autozone/par.../N-jefttZ9pdak
94 honda del sol si part number 432352
http://www.autozone.com/autozone/par.../N-j0zexZ9pdak
dont ask me why
Old Sep 10, 2010 | 03:11 PM
Deetz's Avatar
Crazy Honda Guy
^^ Trust me, i am not wrong, autozone is!!!!!!!!!!
They are two different rads, and they have screwed up
Old Sep 10, 2010 | 03:13 PM
300whpej's Avatar
they have a dual core that comes up in the listing, but it is discontinued. o'reily's, advance, napa, and carquest all have the same part number in my area. there's not even an auto/manual option anymore.
Old Sep 10, 2010 | 03:22 PM
Deetz's Avatar
Crazy Honda Guy
Well, when i look up the oem Honda rads for say a 2000 civic.....here is what they are
b series- 19010-P2T-A01
d series- 19010-P03-505
The difference in the water necks would be really annoying between the two!!
Old Sep 10, 2010 | 03:32 PM
BryanM.'s Avatar
Resident Gearhead
No doubt about it, B-series radiators have larger diameter water necks than D-series radiators.
Some say it's ok to use a D rad for a B motor, but I wouldn't do it.
hulsey
Jul 4, 2012 04:06 PM
Natural Aspirations
14
Dec 8, 2005 01:17 PM
dawrenn
Aug 12, 2005 06:02 AM
Kista20
Jun 21, 2004 06:22 PM
coolguyr
Oct 27, 2001 06:18 PM
