99-00 civic Double Din trim ring help
Old Sep 9, 2010 | 04:36 PM
Myh4tch's Avatar
Default 99-00 civic Double Din trim ring help
I'm having troulbe installing the trim ring that comes with the crutchfield trim kit.
It wont fit correctly in the opening without bending at the top and bottom, has anyone had any experience installing one of these trim kits in this vehicle?
Old Sep 9, 2010 | 04:55 PM
Cobb2819's Avatar
Default Re: 99-00 civic Double Din trim ring help
are you talking about it bowing out, or bending into the radio opening?? if you're talking about it bending, some kits require slight modification to fit. there should be "guide" that came with the kit, look up 99-00 civic, and it will tell you which tabs to cut off
Old Sep 12, 2010 | 09:22 PM
Myh4tch's Avatar
appreciate it, I wasn't cutting off all the tabs on the trim ring. Make sure if you are installing the crutchfield trim ring you need to cut off all the tabs except for the ones specified, which is believe is "B" and "H" but double check on the instructions and it fits fine.
Old Sep 15, 2010 | 07:55 PM
hms_2000si's Avatar
That's why I don't use the dash kits! they don't fit very well.
hondastrtracr
Audio / Security / Video
Nov 24, 2007 06:52 PM
movement01
Jan 30, 2007 11:38 PM
95excoupe
Dec 13, 2002 07:25 PM
