im sure this isnt normal...
Old Sep 18, 2002 | 11:13 AM
HatchBox's Avatar
Skoobie no more...
Default im sure this isnt normal...
ok so i put my srings in...and the fronts are fine...but when i jack the *** end up the springs com out of there boot and just sit there..i can move them up and down..i got h&r sport srings...with some gass rider struts from autozone...is that my problem ...when we installed them they didnt need to be compressed at all...help asap pleace
Old Sep 18, 2002 | 11:17 AM
markedOO1's Avatar
Default Re: im sure this isnt normal... (xxkenyon419xx)
..that's pretty much a normal occurrence with lowering springs..think about it, they're gonna be shorter than the stock springs they'll stay put once the weight of the car is on em..
Old Sep 18, 2002 | 11:24 AM
guttedEF's Avatar
Yeh, the weight of the car will hold them in their perch.
I used to have some cheap HPmotorsports coil-overs, and whenever the weight would be lifted off of the rear passenger tire, it would will around like you're seeing. Sometimes, it isn't in it's correct position all the weay down in it's perch when the weight of the car comes back down. Finally, you'll you hit a bump or something to knock it back into place. When it does go back in due to a bump or something, you'll hear the loudest POP you've ever heard your car make.
My car is completely gutted and the first time it happened I thought someone threw a huge rock at my car or something.. lol
It never heard anything, was just extremely annoying so I got some better springs. And I did learn the hardway that you DO NOT cut corners on your suspension, you will regret it every time you drive your car.
SD_EM1
Jun 7, 2003 08:30 AM
Ben Ogle
41
Jan 22, 2003 11:25 AM
mdpalmer
Aug 5, 2002 09:05 AM
Weston
Jun 11, 2002 03:01 PM
wusta515
Jul 23, 2001 04:48 PM
