92 Accord Running Rough & Hesitating
accord with 175k, Drove home from work fine, went to leave right after & now its Hesitating & running really rough. No CEL, 155psi per cylinder, Getting Spark on all 4-cylinders, Fresh set of NGK plugs. Wires have Resistance from 6.8-8.4 ohms.
Need Help, What else can i check?
Are you sure about the ohms? Seems they are supposed to be xx K ohms per foot.
Is the EGR valve stuck open? That would ruin the idle, and possibly make it run rough until it got to high speed. You can check by blocking the vacuum line and making sure the valve is mechanically closed.
tom
tom
1baddcivicsi
Sep 9, 2010 09:31 AM
