accord running rough & sounds Horrible
Old Sep 9, 2010 | 09:19 AM
1baddcivicsi's Avatar
Default accord running rough & sounds Horrible
92 accord, 175k. Drove home from work fine yesterday, then 30-mins later i get down the road & its hesitating & missing bad. Fresh NGK plugs, cleaned & Injectors, i got a spare coil, installed & no change. 155psi on all cylinders, & im also getting spark on every cylinder.
Im lost, need help, what can i check next????
Old Sep 9, 2010 | 09:31 AM
Ron454321's Avatar
Default Re: accord running rough & sounds Horrible
My issue was plug wires, spark was contacing metal instead of the plugs. You may be getting spark on the cylinder but doesn't mean it's always reaching. I found this out after replacing plugs, fuel filter, ignition coil, cleaning injectors and finally did the plug wires. The only other thing I could have narrowed it down to would have been the distributor but fortunately I didn't need to. Good luck with yours and BTW this is the Civic forum, they are probably going to move the thread.
HondaKingJr
Jul 16, 2013 09:51 PM
Ct93CB7
Nov 26, 2010 07:19 AM
bighedstev
Apr 7, 2007 02:23 PM
94_del_sol
Nov 10, 2005 05:01 PM
Slink_Kardia
Mar 17, 2002 05:25 PM
