ITR stiffer than regular integra?
Old Sep 8, 2010 | 10:45 PM
FURACERMAN's Avatar
Default ITR stiffer than regular integra?
I read that the ITR's chassis is stiffer than a regular integra's. Not just the suspension, and body stiffeners, but supposedly they used thicker material in the rear section of the body...? Can anyone shed some light on this for me? I've been searching but no one has a solid answer so far.
Old Sep 8, 2010 | 11:33 PM
keepinitrehaal's Avatar
Default Re: ITR stiffer than regular integra?
This is the first time i hear this.
Old Sep 8, 2010 | 11:40 PM
YellowKahuna's Avatar
OK noobs, learn
Old Sep 9, 2010 | 02:20 AM
Rene1123's Avatar
wut wut wut!!!! thats blaspheme!!!!
Old Sep 9, 2010 | 09:33 AM
eg6ajk's Avatar
o'rly.....But still lags behind the 4dr sedan in terms of strenght
db8>dc2
Old Sep 9, 2010 | 09:37 AM
Just a n00b's Avatar
Accident Prone
but not in terms of coolness.
Old Sep 9, 2010 | 10:46 AM
Todd00's Avatar
I said I don't want a title!
db8>dc2
The sedans are stiffer than a normal DC2, but they are still more of a flexible flyer than the DC2R chassis.
Old Sep 9, 2010 | 03:11 PM
Peewee's lol
db8>dc2
db8<dc2R
What the Db8 has is a bit more of a wider stance in the rear than the R and thats about it, oh yea, and two more doors.
Old Sep 9, 2010 | 03:25 PM
BlueIntegraBoy's Avatar
More junk in the trunk
Old Sep 9, 2010 | 05:45 PM
Little_Nolan's Avatar
Peewee's lol
db8>dc2
db8<dc2R
Having owned (and tracked) both a USDM 97 R and a JDM 97 DB8 R. I can def. say that the 4dr does feel more solid and planted than the 2dr's. BUT I enjoyed my 2 dr more interms of driving pleasure... IMO they are so close that is it doesnt matter and it really comes down to personal preference.
I must say tho 97' USDM R > ALL
And to keep this related to OP's question, the 4drs do have a rear performance rod aka "trunk brace bar" it is just located under the rear bumper cover and not visible inside the trunk like the DC2's.
Old Sep 9, 2010 | 07:20 PM
I wonder if the JDM DB8R's were reinforced like the DC2R's in those respective areas.
Anyways 4dr<2dr
Old Sep 10, 2010 | 07:33 PM
bsmith100's Avatar
Anyways 4dr<2dr
Definitely.
Old Sep 10, 2010 | 07:56 PM
Anyways 4dr<2dr
Yes they were.
Old Sep 11, 2010 | 11:17 AM
Todd00's Avatar
Yeah, the DB8R was reinforced as well. However, with the 4-door came a weight penality. This was covered in a Best Motoring vid back in the day and ultimately the 4-door was slower around the track.
However, the USDM DB8 was just a "standard" non-reinforced chassis.
Old Sep 11, 2010 | 04:08 PM
FURACERMAN's Avatar
Wow thanks! So, to the track guys: does the chassis make that much of a difference, compared to, say, a GSR, or a GSR with stiffener bar?
Old Sep 11, 2010 | 04:55 PM
Todd00's Avatar
The ITR is superior in every facet to the GSR. Chassis is stiffer, bushings are stiffer, running gear is stronger (brakes, hubs, etc). This doesn't even factor in shocks/springs/swaybars or tranny/motor.
Point is, it's not all about chassis stiffness. There are a lot of factors that make a car "fast" around a track. But the chassis is the backbone of the car, so you might as well start with a good one.
Old Sep 11, 2010 | 05:01 PM
MidShipCivic's Avatar
Hasport used a 4 door Integra, now stock vs stock yeah it's stiffer, but you can easily change this.
Stiffness means a lot you're suspension compresses and that's really the only thing thats suppose to compress not the frame.
Old Sep 11, 2010 | 11:30 PM
Aquafina's Avatar
Then the engine setup and some other items were banned from HC because it killed everyone else.
Old Sep 30, 2010 | 12:50 PM
MartGSR's Avatar
I own a GSR for couples years and I bought an R last year R. On my GSR i have tried Koni yellow with GC coil over 500/600lbs spring rate, rear R sway bar but I can easily feel that the R is stiffer and more "stable". Kinda hard to explain but you definetly have a better feeling with the R. Especially in the turns.
On the first time on the track with my R, i did some stupid spin out cuz it was really a different driving/car than my GSR.
Old Sep 30, 2010 | 01:49 PM
GUILOTINE's Avatar
Kill Gil
I have a stiffie as well
Old Sep 30, 2010 | 01:51 PM
Gil, I saw you went to the Pads game last night. You think they will catch up?
Old Sep 30, 2010 | 02:49 PM
racebum's Avatar
if a stiff chassis is what you're after, weld in the roll cage, this by itself will add more rigidity than any other single mod i can think of.
Old Sep 30, 2010 | 08:16 PM
A roll cage can add just about 0 reinforcement until the car is rolled.
Rule book rule book.
Old Oct 1, 2010 | 02:23 PM
racebum's Avatar
not even remotely true, a cage adds an incredible amount of reinforcement to the chassis. you're basically boxing the entire car together with chromoly tubing
Old Oct 1, 2010 | 06:13 PM
Accident Prone
I think you mean safety, not reinforcement.
