H22A Wiring help
Hello this is my 1st post and i am in need of some really good help
I've got a Rover 600 (whch is a Honda accord just the bodys diffrent)
it came with a F20 (F20Z1) 2.0 single cam non vtec and car is a 1994
Now i've got a H22A out of a auto prelude (also 1994) fitted a H23A manual box to it got a manual ECU (3 plug same as on the car already) and everything ready to work been told need to add wires to get Vtec to work looked online but something i can't seem understand how or where to wire i am really stuck
Please help or can i but a loom or anything which would work
Thank you
Thank you
ok man sup first if the ecu is jdm u dont need to worry about the oil pressure switch,then u going to go and see the wire on your vtec solenoid right next to the ignition,that wire is the one u have to wire up. what u have to do is get online a obd1 pin out diagram. depending on what ecu u have.u gonna check the pin where it says vts vtec solenoid in that spot there should be nothing in there, thats were u gonna put the green wire from the vtec solenoid next to the ignition. if u have any questions just message me.
Hi thanks the ECU i got is also JDM and uprated so win win lol (P13 if helps)
Which loom is best to start with the H22 auto one or mine F20 man loom so stuck it's doing my head in lol
i know i need to swap the ingector wireing over but this all looks diffrent too
Thanks for a reply so far
ilovemyb16a
May 18, 2006 12:58 PM
