coolant leaking?
Old Sep 8, 2010 | 03:11 PM
forestcd6's Avatar
Default coolant leaking?
I was few ?'s. First my car is leaking coolant from the driverside from just above the axle. not sure where it's coming from. Any idea's? I'm thinking of removing my power steering, a/c system and cruise control. that should free up some room in that area.
Old Sep 8, 2010 | 03:25 PM
Sorcerer's Avatar
Default Re: coolant leaking?
Has your water pump been replaced? It could be coming out of the timing belt cover which would make the leak hard to find. If the water pump is puking out the weep hole it's time for a replacement.
It isn't an impossible fix but will require some patience....
cheers
Eric
Old Sep 8, 2010 | 03:58 PM
nhldogg's Avatar
The year model and engine size of your car would help...
Old Sep 8, 2010 | 06:35 PM
forestcd6's Avatar
1995 honda accord ex 2.2 v-tech
Old Sep 9, 2010 | 08:22 AM
JusAccord's Avatar
I bet its the water pump, I had the same issue wit my accord, so get that water pump change bro
WingedMan
Apr 26, 2021 05:03 PM
justint7121
Nov 21, 2010 09:46 PM
rbwdriven
Nov 6, 2008 09:48 AM
wedtm
Mar 26, 2008 07:59 PM
1baddcivicsi
Apr 24, 2006 07:33 PM
