For sale: Built Ls/Vtec
Built by: Bailey Motor Sports 4787 garden ct, Sun prairie WI
By: John Bailey himself
Includes: Ls/vtec kit, P28 ecu(chipped), obd1 wiring harness, 1st gen. Skunk2 intake manifold, clutch, pressure plate,brand new dizzy, and flywheel.....
B18b Block
B16a2 Head
Piston kit w/rings, Arp rod bolts, STD main bearings(ACL), STD rod bearings(ACL),thrust bearings ACL, Napa cam seal, Lower set Fel-pro, Head set, INT set, Valve cover set, Remain oil pump, Dual spring kit, Arp head stud kit, Intake and exhaust valves.
3 angle valve job, Resurfaced Cyl head, Bore and honed cyl, Resized Con rods, Fit rods (pressed) polished crankshaft, and all was Pressure checked
Have RECIEPTS!!
Call or text 608-772-7521
B18b Block
B16a2 Head
Have RECIEPTS!!
doesn't come with tranny, and not sure the lsv conversion kit the previous owner of the car had it done in new jersey before i bought it, then later on i rebuilt it due to 3rd cylinder pressure being lower than the rest
It can actually go either way! i built it with boost in mind but its like 10:1 made 250whp with 5psi E85. Its has the arp rod bolts and headstuds, along with high pressure head gasket and all the good stuff needed for boost
honestly to tell you the truth i dont even know, i guess you throw me an offer ill consider it and see if its worth seperating....But just something to consider it is a rebuilt head with dual valve springs,valves, 3 angle valve job and all that good stuff...
Open for trades such as: Gsr leather seats or any other cool seats,wheels maybe,bigger than 450cc injectors,suspention for integra, drilled and slotted rotors (front), front speakers,
