Shop sale: CP, Brian Crower, Mfactory, FJO, AEM, OEM, etc
I have a bunch of items looking to sell around the shop:
Jim Fab solid stabilizer mounts with mint condition OEM mounts: $50.00 shipped
Mfactory 3.07 1st gear, brand new. Lowers 60 ft times. $175.00 shipped.
B-series fuel rail w/-10 a.n bungs welded onto either side. Brand new. $75.00 shipped
Cobalt racing brake pads for 92-00 civic rear or 94-01' integra rear calipers. Brand new. $50.00 shipped.
3-4" v-band transition. $50.00 shipped. 3" GT flange to v-band conversion. $35.00 shipped. 2.5" 4-bolt to v-band conversion: $30.00 shipped.
CP pistons part number SC7012. 83mm, 9:1 b-series pistons brand new in the box with rings, wrist pins, locks, instructions, stickers, etc. $450.00 shipped.
Brian Crower B18a/b +625 connecting rods part number BC6029. These are brand new, and rated at 1000 whp. They have the ultra baller +625 custom age ARP rod bolts rated at 300 whp per cylinder. $475.00 shipped.
Fluidampner Street Steel pulley for all b-series engines. Comes with instructions. In like new condition, only used for 20 passes on a drag engine. $250.00 shipped.
2 obd-1 acura integra engine harnesses in excellent condition. One harness has all stock connectors on it, the other has a AEM 3.5/5 bar map sensor plug on it. $125.00 shipped on each of them.
Quaife LSD for B16a ring gear pattern. Used for a handful of passes on our all motor b-series drag car, in like new condition. Comes with new OEM honda diff bearings and VSS ring gear sensor pressed onto it. $500.00 shipped.
ITR/CTR transmission case brace. $50.00 shipped. Comes with all OEM hardware.
Brian crower stage 3 n/a cams. Great big turbo cam, with really high quality cam cores. These work extremely well in high power turbo engines. These cams are brand new in the box. Cannot be used with oversized valves. $350.00 shipped.
GM 3 bar map sensors and harnesses. Brand new. $50.00 shipped on each.
GM boost solenoid and harness. 30.00 shipped.
00-05' s2000 FI/C with plug and play harness. 100% plug and play, with vtec window switching point editable within the FI/C with the additional relay. $300.00 shipped.
FJO single channel wideband controller and brand new NTK o2 sensor. This is the cheapest and most reliable wideband I have used. This is my spare one that is brand new in the box. Picked up a Motec PLM for the shop awhile back, so no need for the FJO anymore. My loss is your gain. $300.00 shipped for controller and sensor. Sensor alone is over $200.00!
All prices are firm, and shipping is within the 48 states only. Any questions you can PM me on here, or email tech@evans-tuning.com.
bump for jeff.. lots of nice parts as usual.. hows the new shop coming? I called and left a message , consider the s2000 fic sold
boosted hybrid
Sep 15, 2010 06:17 PM
boosted hybrid
Sep 12, 2010 05:45 PM
buuump
