cam selection help
im wondering if someone here could point me in the right direction in a good set of cams for the mods i have/plan.
i have a civic vti mb6 which has a dc2 itr bottom end and stock b18c4 head, i have bought a set of spoon cam gears, toda dual valve springs, c+r titanium retainers, and a set of type r LMA's (was suppose to get spoon cams but they were worn so the seller didnt sell).
I dont really want to go about replacing pistons and doing any work on the bottom end (at the moment anyway) so really just looking for a set of cams which will give some nice power and still be safe enough to drive for a daily car.
Also any other parts that i will require, as i will be buying all the parts required to the mechanic for fitting. i would like skunk2 pro2's but been told i need work done to the bottom end for them to perform
Cheers in advance
Car:
Cheers in advance
Car:
Skunk 2 tuner series cams maybe as they are much easier to tune. Rocket M22x cams would be similar, easy to tune and make more power. Pro series are harder to tune and you really need to measure your V2V clearances when installing them and before tuning the cams etc. Do you run any kind of tuning system on your car now?
