Pic Request: XXR 002 ON EG HATCH
I just got a set of XXR 002 Rims, and i just wanted some ideas on how it looks on your eg hatch's and some info.. like what type of camber kits is good to purchase, and also what size and type tires is a good combo if im gonna lower the car? please post thanks
if they are low offset you would have to run 195 45 15s and nothing bigger then that. also a camber kit would be needed and you may have to roll your fenders. sounds like a lot of work but its worth it.
Thanks for the info and help! Anyone got pics? I seen on google but need more thanks
Assuming they are 15x8, you CANNOT safely mount any of the following tire sizes on there:
195/45-15
195/50-15 (the best tire size for your '92-95 Civic)
195/55-15
205/50-15
The ONLY tire size you can safely mount on there and have a prayer of using without rubbing - and even then, you probably can't - is 225/45-15.
195/45-15
195/55-15
205/50-15
slide inside
Sep 22, 2010 05:16 PM
