Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone have PasswordJDM tri brace in EG hatch?
Old Sep 6, 2010 | 02:34 PM
boostntofu's Avatar
Default Anyone have PasswordJDM tri brace in EG hatch?
Having fittiment issues with it. Have Skunk2 Pro' S coilovers.
Seeing if anyone has had the same problems. I think I am going to have to get a dremmel and make the mounting holes on the bar longer to fit over all the strut tower threads.
Old Sep 6, 2010 | 02:46 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: Anyone have PasswordJDM tri brace in EG hatch?
You might have a bent frame??? How far off are the holes?
In regards to the product, I like the way it looks but the portion that mounts to the firewall isnt the most sturdy place to mount it.
Its just sheet metal and thats it. So will you get any benefit(stiffening) from it, I have my doubts.
I use the DC sports shock tower model 2 point. Its adjustable.
Then again there are those who say the braces dont help much anyway.
Old Sep 6, 2010 | 03:03 PM
Reyes's Avatar
is the car still on the ground? we installed on on my friends car and it was easier to jack the car up and loosen the coilovers so they dropped down out of the bay a little bit.
doing that gave it the room to fit right in.
Old Sep 6, 2010 | 06:08 PM
Lo-Buck EF's Avatar
STBs do nothing on upper and lower a-arm suspensions. return it and save your money.
Old Sep 6, 2010 | 07:04 PM
night's Avatar
how about with struts
Old Sep 7, 2010 | 07:36 AM
cruizinmax's Avatar
Why does the factory install them then?
Old Sep 7, 2010 | 10:17 AM
GI8U2racing's Avatar
I'm no suspension guru, but in what I've read and in my experience hearing the creeking of my 23 year old CRX lugging 2500 lb around, the more chassis bracing, the better. Sure, some may be more strategically placed, but a FSB is not a total waste of money.
Old Sep 7, 2010 | 01:47 PM
Lo-Buck EF's Avatar
on a strut based car, yes. because all the load goes right through the strut tower in one spot. i put one on my old strut based car and it made a great improvement. i put one on and off 3 of my civics in various layouts and it never made a bit of difference.
cause it makes the engine bay look nice. it doesn't make a bit if difference. but if you would like to believe Honda put them there for some special handling gains, go ahead.
Old Sep 7, 2010 | 01:52 PM
night's Avatar
ok, then. Thanks for the reply. Now to look into getting a rear one made for mine.
Old Sep 7, 2010 | 03:18 PM
kristo's Avatar
Loved
Maybe a car 'feels' some things that the driver doesn't.
Lap times are the referee.
Old Sep 7, 2010 | 06:02 PM
Lo-Buck EF's Avatar
ok, lap times showed ZERO difference with the same alignment, same tires, same track, ect.
happy?
Old Sep 7, 2010 | 07:48 PM
Jaker's Avatar
But the inboard mounts of the upper control arm are in the same vicinity as the top of the shock, so the cornering forces imparted to the chassis at the UCA inboard mount can be triangulated by the attachment of the FSB at the shock tops.
However, since you said there was no change in lap times, I guess it just doesn't work.
Old Sep 8, 2010 | 03:25 AM
Lo-Buck EF's Avatar
You are all welcome to buy a stb and try it for yourself.
da9ine
Suspension & Brakes
Dec 3, 2018 11:15 AM
4g4dcruisin
Apr 1, 2010 02:45 PM
boostedefhatch
16
Apr 10, 2009 06:42 PM
iheartmyej8
Nov 27, 2008 11:28 AM
