3rd Gen D2J3 vs D2J4 - Electric vs Mechanicle Speedometer
Old Sep 6, 2010 | 12:00 PM
408Honda's Avatar
Default 3rd Gen D2J3 vs D2J4 - Electric vs Mechanicle Speedometer
Right now my 89 SI 4WS is running:
- JDM B20A motor
- USDM Intake Manifold (ITM)
- USDM Exhaust manifold (EM) [with all o2 sensors, which connect to the (EM)]
- USDM Transmission D2J3
The transmission is beginning to slip and go bad however.
I have a D2J4 transmission that came with my B20A when I bought it, but I was never able to put it in since the speedometer that goes along with it is electric. and the car is set up for mechanical.
How would I go about putting in the D2J4 transmission and having a speedometer?
408
Old Sep 6, 2010 | 04:13 PM
408Honda's Avatar
Default Re: 3rd Gen D2J3 vs D2J4 - Electric vs Mechanicle Speedometer
Correction: let me explain what is going on a little more.
When I drive the car, it is EXTREMELY hard to shift into 2nd gear. It will engage into 2nd at low RPM's, but at higher RPM's it won't catch until the RPM's have dropped.
Also there seems to be something slightly wrong with 3rd gear. It engages into 3rd fine, at any RPM, but as you drive, sometimes around 3500 RPM it feels like it "grabs better" and pulls harder, but only sometimes, other times it is OK.
The clutch feel fine to.
here are some pictures of the Transmission stampss, and the D2J4 speedometer.
408
Old Sep 8, 2010 | 05:20 PM
melkor's Avatar
I would try contacting Hasport and see if the mechanical speedo will drop into the tranny that came with the B20A. I'm pretty sure they did something similar with their H22 powered CRX that was featured in Sport Compact Car a while back. It may be something as simple as that. Good luck with your build man!
Old Sep 9, 2010 | 09:00 PM
InvaderTrax's Avatar
In the D and other B transmissions, you can alternate mechanical and electronic speed sensors, so I would not be surprised to find that yours is the same way. And I doubt HASport would know, considering they've probably never touched a B20A
Old Sep 10, 2010 | 11:20 AM
Hasport's Avatar
the mechanical speed sensor will work in the JDM transmission
Old Sep 28, 2010 | 11:28 AM
melkor's Avatar
Well there you go.
Old Sep 29, 2010 | 10:12 PM
1funryd's Avatar
Just take your old speed sensor from your old tranny and swap it right over. They are the same.
cachehx
Jan 17, 2008 04:29 PM
Karterguy13
Jun 15, 2004 11:15 AM
NightHawkC5
Dec 6, 2002 10:33 PM
HX_Guy
Jul 11, 2001 01:10 PM
