where is my knock sensor and my oil pressure on my motor?
knock sensor is on the back side of the block right above the oil filter. you might be asking about the vtec oil pressure, which is on the vtec solenoid next to the distributor.
1)the green plug over the oil filter is the knocksensor or the oil pressure?
2)and the white plug underneath the vtec solinoid vtec oil pressure?
2: if i remember right on my 1st gen b16 it was a green plug ON the solenoid assembly.
so the four wires are :
1)vtec oil pressure/green plug ON the vtec solinoid
2)knock sensor/green plug obove the oil filter
3)2nd o2 sensor/next to the other one
4)vtec wire/????????????
