K24A4 - $300 - Trade for LCD TV if local
Contact: PM/Thread Text 704-754-0762
Trade Wanted: B series stuff. B16/GSR Transmission. Flywheel/clutch kit (preferably aftermarket clutch) let me know. LCD TV
I have a K24A4 long block. NO TRANNY OR ECU. I bought this thing about a year ago from someone on Carolina Hondas. Can't remember who. He claimed it had around 30k miles and he bought it from Hmotorsonline.com. Engine has NO problems, except for the thermostat housing is cracked. Read below for parts list.
I WILL DELIVER IF YOU'RE 1.5 HOURS FROM SALISBURY, NC
Other than that it is shipping at buyers expense.
PART OUT!!!
SHOOT ME A PRICE AND ILL LET YOU KNOW
$300 TAKES EVERYTHING OBO
K24A4 Block (can still see the Cross Hatching from Honda in the cylinder walls) PENDING
K24A4 Head (stored PROPERLY on wood so that it doesn't get scratched)
K24A4 Pistons & Rods (didn't picture those) PENDING
K24A4 2-Piece Intake Manifold
K24A4 Cable controlled Throttle Body PENDING
K24A4 Harness (I think its both the charge and engine harness)
K24A4 Fuel Rail and Injectors
K24A4 Water Pump
K24A4 Head/Exhaust/Intake Gaskets
K24A4 Timing Components (Minus Chain. Which you would need to change over if doing Frankenstein anyway.)
Random bolts and block mounts
SOLD
K24A2Pistons & Rods (With these TSX pistons you will get the proper valve clearances. Found 3 of the brand new OEM ring sets. Cant find the rest.) -
K20A2 Oil Pump with pickup (RSX Type S. This will allow you to do a Frankenstein and keep up oil flow)
K24A4 Timing Cover
K24A4 Starter
K24A4 Clutch
K24A4 Flywheel
K24A4 Pressure Plate
Bad:
Thermostat Housing is broken ($27 from any Honda OEM retailer online)
I THINK thats everything
VIN: 1HGCM55304A131352
PART OUT!!!
K24A4 Water Pump
SOLD
K24A4 Timing Cover
K24A4 Starter
K24A4 Clutch
K24A4 Flywheel
Bad:
leroyb
Northern California (Sales)
Apr 15, 2009 07:29 PM
SwappedTURBOegg
Dec 25, 2008 07:38 AM
