IL (BUILT&TURBOCHARGE{93 DEL SOL S}GSR SWAP
This is a 1993 Honda Del Sol S, with a gsr(b18c1) swap w/ 93 b17a1 gsr-head. It recently got repainted black by Maaco. It has the 1997 gsr front & rear brake conversion, The head was just rebuilt it has less than 5,000miles on it. Engine is built to handle 18lbs of boost. I have the receits to prove for parts, just the Lsd Quaife was 1500. Practically all the parts are NEW Its a quick car and very reliable. It has a targa top which is great for the summer
well if you have any questions let me know!! 712 269 3352 or pm me.... 6500 or best offer.......TRADE FOR EK BOOSTED HATCH OR B-SERIS OR K-SERIES SWAP........
****************may need a tune*************
Engine-HEAD 93/Gsr-(b17a1)Less than 5,000 miles on rebuilt
-Edelbrock Victor x intake manifold
-Blox 70mm throttle body
-Golden eagle turbo cams
-Hasport engine mounts
-obd2 dizzy w/ MSD obd1 adapter MSD wires
-Felpro valve cover gasket(new)
-Blox plastic intake manifold gasket(new)
-Blox rear cam seals(new)
-Timken front cam seals(new)
-Cometic head gasket(new)
-Cometic exhaust gasket(new)
-Oem honda water pump(new)
-Oem oilpump(new)
-timing bel tensioner(new)
-Wrinkle painted black sparkplug cover
Engine-BLOCK-(b18c1)81mm
-Cp 9-1 low compression forged pistons
-Scat rods(new)
-Acl bearings(new)
-Arp rod & head bolts(new)
-Fel pro oil pan gasket(new)
-Tapped welded oil pan with earls plumbing fittings
Transmision-(98 Ls)
-Act stage 4 clutch
-Resurfaced oem flywheel
-b16 gears
-Quiafe Lsd
-Aftermarket bearings
Turbo-
-Precision 60 trim
-Tial 38mm wastegate
-Greddy type s b.O.v.
-Cast Iron manifold
-Emotors 2 1/2 turbo piping & coupler
-Intercooler
-Chipped p28 on a base map (9psi)
-Full boost 16-18lbs (350-400whp)
-Low boost 8-12lbs (240-280whp)
Fuel Delivery-
-400cc low impedence injectors
-Walbro 255LPH fuel pump
-Golden eagle fuel rail
-Blox fuel regulator
-Blox pressure guage
-NGK iridium platinum spark plugs, the 10$ plugs(new)
-Steel braided fuel line with new fuel filter
Exhaust-
-Custom 2 1/2 piping with vibrant exhaust
Wheels
-Rota slipstreams
-Falken azenis tires
Suspension-
-Tokico struts
-Meagan coilovers
-Blox front control arms
-Blox rear lower control arms
-Prothane bushings(new)
-Rear trailing arm (new energy suspension bushings)
Brakes-
-97 Gsr front & rear brake conversion
Exterior
- New paint job from Maaco (black)
Interior-
-Gsr leather front seats
-Boost,water temperature, and oil pressure Gauge
-Autometer 5' tachometer
-Apexi vafc2 vtec controller
well if you have any questions let me know!! 712 269 3352 or pm me.... 6500 or best offer.......TRADE FOR EK BOOSTED HATCH OR B-SERIS OR K-SERIES SWAP........****************may need a tune*************
-Oem oilpump(new)
-Scat rods(new)
-Acl bearings(new)
Transmision-(98 Ls)
-Act stage 4 clutch
-b16 gears
-Quiafe Lsd
Turbo-
-Precision 60 trim
-Cast Iron manifold
-Intercooler
Fuel Delivery-
Exhaust-
Wheels
-Rota slipstreams
Suspension-
-Tokico struts
-Meagan coilovers
Brakes-
Exterior
Interior-
kdoggparker
Oct 28, 2010 11:51 AM
hondadelsol93
Nov 18, 2007 01:55 PM
silentbeatz
Sep 15, 2007 12:45 PM
