drive without sway bar bushings
Old Sep 5, 2010 | 05:10 PM
marks97el's Avatar
Icon2 drive without sway bar bushings
I was in the process of changing out my sway bar end links and bushings. I was doing the front and the bolts that hold on the bushing...3 of 4 of the bolt heads sheared off.
Is it okay to drive a short distance to the shop without the bushings in there?
Old Sep 5, 2010 | 05:23 PM
cleansi's Avatar
Default Re: drive without sway bar bushings
sure , you could drive with out the entire bar if you wanted probally wouldnt even notice a diffrence either
Old Sep 5, 2010 | 10:01 PM
marks97el's Avatar
My concern was without the bushings if the new end links i put in would get destroyed.
I ended up just putting the old bushings there, and then put in the only bolt for 1 of the bushing clips in. I think it all went okay. I drove slow and didn't do any suden turns.
dtran002
Nov 6, 2007 05:51 PM
b18LS
Suspension & Brakes
Oct 10, 2007 05:16 PM
pyrojeff
Apr 25, 2005 06:31 AM
ragejed
Sep 25, 2002 04:40 PM
