CO FS/T: 93 Civic Coupe B16 Turbo
Posting this for a friend.
93 honda civic ex coupe:
car
Mileage: 151xxx (chassis)
color: tahitian green
interior: alpine cd player (new),no back seat ( i have all the parts to put it back together), autopower roll cage (painted car color)
exterior: gt3 gold 16",3000 hids,front oem lip,eagle tow hook,carbon hood
brake:rear disc, front powerslot disc and hawks pads
trans: type r trans, 6 puck unsprung
engine: B16a,eagle block guard,eagle rod, arias pistons.red valve cover
axels :new from importsport
fuel pump: fi holly pump
turbo : 60-1 garett,1000cc presision,s300,tial blowoff,presicion 39mm wastegate.
bad: no seat,small crack in the hood,windsheild is crack
car just got switch to e85, we had issue on the dyno where we could not turn up the boost and i fixed bunch or leaks that were found so now should be good.
7000 for the whole car
4000 for the hole engine trans turbo swap
everything is best offer
car has a cat with an opendown pipe availaible. it is fully emmissionable
tuned on e85 at 12 psi at 320whp and put down 402whp at 19psi on pump gas
car is rust free. in good shape for the age.
no leaks,no smoke, compression test is 115,120,120,120
open for trade maybe.i can put a little money on my side, i can do less with some of the parts, like 6500 without the cage.
7202431039
julien
pictures here
http://denver.craigslist.org/cto/1938072985.html
car
7202431039
julien
pictures here
