Please HELP! Injectors wont fit???
i am installing precision 650cc saturated injectors. This is an obd1 gsr engine. The problem is when i go to put them in the injector clips they only go half way and then stop. While the stock ones go in perfectly. They look almost exactly the same besides a small plastic piece in the middle of the 650cc injector clip part. Any info will be very helpful. Thanks.
im telling you just cut that little plastic piece out and it will work, or you have to end up getting a harness, went through this with RC injectors also before i switched to ID
00Red_SiR
Apr 27, 2008 08:19 AM
97turboteg
Apr 25, 2006 03:56 PM
