D16z6 clutch and flywheel in d16a6?
Old Sep 18, 2002 | 06:17 AM
DsMWookie's Avatar
Default D16z6 clutch and flywheel in d16a6?
I am buying a whole d16z6 swap for 600$ it has a stage2 clutch and 8-9lb flywheel. Was wanting to know if I can use the flywheel and clutch from that tranny ?
Old Sep 18, 2002 | 06:41 AM
RyanR's Avatar
Default Re: D16z6 clutch and flywheel in d16a6? (forward_motion_crx)
If you have the transmission that came with your 89 CRX and not an 88 trans, yes, it will work fine.
Old Sep 18, 2002 | 07:25 PM
DsMWookie's Avatar
Default Re: D16z6 clutch and flywheel in d16a6? (RyanR)
how can i tell the difference?
Old Sep 18, 2002 | 07:36 PM
MrTodd's Avatar
Well what year is your car? 89-91 Si trannies should have 22 (right?) splines, while the 88's should only have 21. Just pull off your tranny and take a look at the mainshaft, count the splines. Or if you have the clutch disc there, see if it slides onto the mainshaft.
But yes, if you have a 89+ tranny, all Z6 clutch compenents will fit - well flywheel, clutch disc and pressure plate that is.
Edit: Sorry, I see by your sig that you have a '89, so like ryanr said - If you haven't installed a different tranny in your car, you should be fine.
[Modified by MrTodd, 9:37 PM 9/18/2002]
Old Sep 18, 2002 | 09:49 PM
Louie B.'s Avatar
Default Re: D16z6 clutch and flywheel in d16a6? (MrTodd)
89-00 = 20 splines
88 = 21 splines
SFlCrx
Apr 19, 2012 08:36 AM
LsVtec08
Transmission & Drivetrain
Jan 4, 2011 06:59 PM
g_rant2006
Feb 6, 2006 08:48 AM
EJ1 wilcox
10
Sep 9, 2005 08:06 AM
brent_G
Oct 7, 2003 07:52 PM
