Bad mileage running too rich help!
Old Sep 4, 2010 | 02:53 PM
brian8702's Avatar
Default Bad mileage running too rich help!
running the car and its running to rich.
its throwing a 41 cel for a heater oxy sensor
im unsure about the wiring to the oxy sensor
the wiring for the h22 had a gray,black and two white wires
so i might of hooked it up wrong but i could use some suggestions
Old Sep 4, 2010 | 05:06 PM
Kronn 98SH's Avatar
Default Re: Bad mileage running too rich help!
You should probably mention what car you have.
Old Sep 4, 2010 | 06:41 PM
minilogoguy18's Avatar
There's only 1 way it'll plug up, test the wiring on the harness side, if it's good then replace the O2 sensor. It's a 4th gen obviously.
Old Sep 4, 2010 | 06:42 PM
brian8702's Avatar
ohhh sorry its a 92 accord with a h22a swap
Old Sep 4, 2010 | 08:19 PM
Kronn 98SH's Avatar
No idea why you would assume that.
If you're unsure about the wiring, get the manual of the H22A donor vehicle. Find out if you wired it correctly. I'm assuming you used a universal O2 instead of the direct-fit O2 for some extremely strange reason.
asoRm
Jan 21, 2024 09:25 PM
estawon
Nov 26, 2011 05:32 PM
seanyreeves
Engine Management and Tuning
Oct 12, 2011 10:15 PM
JVHGA12
Sep 6, 2007 08:46 AM
brawl
Sep 18, 2003 03:58 AM
