Front and rear wheel bearings the same?
Old Sep 4, 2010 | 12:05 PM
Shinny's Avatar
Default Front and rear wheel bearings the same?
I'm replacing the studs all the way around my new CRX and I'm wanting to also replace the bearings, I'll I could find online is bearings labeled for the front. Is there really a difference?
Old Sep 4, 2010 | 12:56 PM
jlk16188's Avatar
Default Re: Front and rear wheel bearings the same?
yes, the rear usually comes with the hub and studs as an assembly. I went through the same thing. All the auto parts stores sell the rear bearings as assemblies and the front as just the bearing. Good luck if you need a new front hub, I could only find them directly from Honda unless I would pay over $120.
Old Sep 4, 2010 | 05:38 PM
Shinny's Avatar
I'm getting extended studs tho... o.O I don't need to replace the hub, I'm just getting stuff so the car can handle racing
Old Sep 4, 2010 | 05:41 PM
mattliston's Avatar
The car can withstand racing in STOCK healthy form.
Change bearings only as necessary
hubs need not be replaced when getting longer studs
dont get longer studs unless you NEED them. Almost zero NEED on a honda unless you are a tard using spacers
Zebra
Honda Civic (2006 - 2015)
Jan 20, 2019 06:15 PM
RaysBoomBoomLude
Jul 9, 2008 04:47 AM
redman223
Apr 30, 2007 02:36 PM
bosco500
14
Aug 25, 2005 10:27 PM
Padronis
Jun 23, 2001 07:12 PM
