Wheel sizing technical question
Old Sep 4, 2010 | 08:32 AM
Z_From_NH's Avatar
Default Wheel sizing technical question
My CR-Z has 4 of the same size tires (195/55-16) from the factory, and it also has the same bolt pattern as a Mk2 MR2 (5x114.3), letting me have the ability to use the staggered (17x7f 17x8r) Advan wheels that I already have. I don't see a clearance issue with running a 235/40-17 on the rear, and it won't affect the speedo, since its FWD. The fronts are going to be a 215/45-17, which is close enough to the stock height/rolling diameter to make a negligible difference.
My main issue is: if i run a considerably different size than stock tire (2" wider) on the rear than stock, will I run into any braking issues or any other foreseeable issues?
Hopefully what it would look like:
That huge rear fender overhang:
How they sat on my MR2
ATSGARAGE_Jr
Acura NSX
Jun 9, 2006 01:18 PM
b18ef8
Honda S2000
Sep 8, 2005 09:35 PM
Home Skillet
Honda Motorcycles
10
Dec 6, 2004 04:57 AM
vehic_illu
Aug 13, 2003 09:29 AM
