01 H2F, which axles to use
Old Sep 4, 2010 | 06:25 AM
Twixle's Avatar
ate my pixel
Icon2 01 H2F, which axles to use
Previous owner of my prelude broke the transmission (5 spd) and swapped in an Accord transmission (94). I'm going to be replacing the ball joints and tie rod ends and was going to put new axles in while I had everything apart. Is there any difference in the length or spline count between accord and prelude axles? If prelude axles are compatible with an accord transmission I'd like to use them because I assume they're designed to withstand higher torque from the H22.
TIA
Old Sep 4, 2010 | 08:07 AM
md23vtec's Avatar
Default Re: 01 H2F, which axles to use
TIA
The difference is the half shaft from accord to prelude. The prelude has a male shaft the accord has a female type shaft. Also depending what model accord it may just have the long axle on the drivers side with no half shaft. The previous owner possibly just swapped the trans and kept the prelude axles and half shaft which is fine.
Old Sep 4, 2010 | 09:20 AM
Kronn 98SH's Avatar
I would switch back to an H22 transmission if you care at all about performance (unless you're boosted).
CTCD5
Mar 10, 2017 12:11 AM
femmefataleracer
Sep 25, 2004 04:25 PM
runitup
Oct 14, 2003 06:27 PM
kurt.
Sep 1, 2002 02:32 PM
